Author Topic: PROTECTION MONITOR 50" HELP  (Read 2299 times)
ARCADEMAN
  • Last login:June 18, 2015, 02:10:07 am
« on: July 26, 2009, 01:41:23 pm »
I have a WAVE RUNNER arcade game that has a monitor 50" problem.
When the Main power button is pressed, the LED goes Green and then Red .  I hear the sound of the monitor trying to turn on, but nothing. I hear the 2 relays on the power supply  goes on and then off. The fans work for a moment and then off.The fuses in this monitor look OK i test it.
Pictures of the monitor  is the same like this one  http://www.flickr.com/photos/impulsze/sets/72157600405829679/ .I have replays all the STK IC and a lot  of capacitors.Steel the same.NEED HELP   :dunno
Kevin Mullins
    • Me on Myspace
Re: PROTECTION MONITOR 50" HELP
« Reply #1 on: July 26, 2009, 04:26:59 pm »
The model appears to be a Mitsubishi VS-50SE1 50P-GHS41 if anyone wants to take a stab at it.
Not sure if the original poster can find an actual chassis number, but that might be helpful in research as well.
I rarely touch a projection set if I can help it.
HV shutdown, convergence IC's, pico fuses blown due to bad convergence IC's, caps,  :P
« Last Edit: July 28, 2009, 10:28:54 pm by Kevin Mullins »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: July 26, 2009, 09:47:12 pm »
most projo's have various protection circuits that will activate on a fault . (a service manual would be quite helpful)
a visual inspection is a good beginning . start with the pwr sup. look for domed /leaky 'lytic caps-replace as needed..
same applies to the deflection pcb . also look for burn marks and loose connections .
loss of vert deflection will trigger shutdown. look for poor connections on the vert output ic.
if the HV does come up , the h out xistor is likely ok. however, faulty tuning caps /flyback/HV Distribution block can all
cause shutdown .
convergence failures can cause depending on brand .
i'm not familiar with Mitsu projo's , thus can not give detailed tips.
i'll see if i can find a manual .........  :dunno
good luck
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« Reply #3 on: July 27, 2009, 02:40:22 am »
Check the bulb.  TVs and projectors won't keep power if the bulb is blown.   It could also just not be pushed in completely.
ARCADEMAN
« Reply #4 on: July 27, 2009, 11:33:34 am »
i will  look  for the exact model tomorrow.thanks
qrz
« Reply #5 on: July 27, 2009, 10:12:20 pm »
this is a crt based projo ( i.e. red , blue, green crts)
no uhp lamp or balast to be found in this one .  ;D
not found a print.  :(     it may be a "proprietary" model ...?
ARCADEMAN
« Reply #6 on: July 28, 2009, 12:54:35 pm »
This WAVE RUNNER game has this monitor:
Game Name:     Wave Runner
Cabinet Type:    Deluxe
Monitor Size:    50" (  red , blue, green crts)
Model Number:    50P-GHS41
I am New in this Forum and Thank you all  for trying to help me.If anyone has a service manual or some tips to fix it Please help..... :notworthy:
grantspain
« Reply #7 on: July 28, 2009, 01:59:09 pm »
last one of these i had go was a fault on the power supply board,trouble is the fault could be anywhere-what you need is another one of these to swap until you find which of the boards is faulty
the problem i had was a blown voltage reg
