Author Topic: Tv tube question in mame cab  (Read 1353 times)
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« on: July 23, 2009, 05:32:12 am »
I am looking at building a cab using a tv for a monitor, I have only used PC monitors before so not sure exactly what I need.
I presume I need
TV with s-video
S-video out on video card
Now I would like when I press power button on cab that the monitor comes on and when I shut down PC the monitor goes to standby like a PC monitor does, is this possible.
any help appreciated
cheers
Beretta
Re: Tv tube question in mame cab
« Reply #1 on: July 23, 2009, 02:24:50 pm »
i've never seen a tv with standby mode..
however i have seen several newer models with auto power off after 15mins if they dont have a signal.
there are a few ways to approach this, some depend on the the tv.
1. use a toggle switch to power tv's power, tv must come on after power loss
2. desolider the tv's power button and wire it to a momentary contact switch.
3. if the tv will power on after a power loss, you can wire up a relay to the pc's power supply, or get one of those smart power strips.
4. disconnect the IR reciever, cut a hole in the screen bezel and move the IR to it.. this way you can use the TV's remote though the monitors plexi/glass, retain full control of the tv.
i believe some also have wired the tv's power to the computer in a way to control but i dont know the details of it.
