November 21, 2009, 09:28:42 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Wah!Cade 0.99pre8 "Could it be?"  (Read 472 times)
Balki
Trade Count: (0)
Full Member
Offline Offline
Eh?
View Profile WWW
« on: July 21, 2009, 12:18:51 PM »
Hi,
A new release of Wah!Cade is out...
Available from the usual spot:
http://www.anti-particle.com/wahcade
Wah!Cade is a GNU/Linux friendly clone of Minwah's excellent MameWAH.
Cheers,
Andy
Logged
boxman
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1 on: July 21, 2009, 02:35:17 PM »
Excellent, thanks for all your work porting this!
Is it now possible to run wahcade without a window manager? I currently have to run blackbox and then wahcade from within that. I'll test it out later.
Logged
Balki
Trade Count: (0)
Full Member
Offline Offline
Eh?
View Profile WWW
« Reply #2 on: July 21, 2009, 04:26:07 PM »
I think you'll still need a basic window manager...
Logged
boxman
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #3 on: July 22, 2009, 05:45:04 AM »
Yep, just tested it.
I'm trying to make a wahcade session that loads automatically from gdm for my cabinet. The reason I want to do that is because it shaves a couple of seconds off the boot time and completely hides the OS, so no mouse cursor or anything.
Wahcade loads if you do this but it crashes if you try to go into a menu or start mame.
If anyone else wants to try this for some other program this is how you do it in ubuntu (change name, comment and exec to whatever you want to load):
Code:
sudo gedit /usr/share/xsessions/wahcade.desktop
Then add this to the file and save it:
Code:
[Desktop Entry]
 Encoding=UTF-8
 Name=Wahcade
 Comment=Arcade Front End
 Exec=/usr/bin/wahcade
 Terminal=False
 Type=Application
Then you should have a new option on the GDM sessions screen.
I don't really know too much about the inner workings of linux so I have no idea if this will actually ever be possible or if there is a better way to do it, but it would definitely be great if it did work.
I currently have gdm automatically log in and load blackbox, which then runs wahcade from its autorun script. It works perfectly fine but the mouse cursor still shows for a couple of seconds.
This is my only niggle with wahcade, other than that it is perfect, so thanks again!
Logged
dirkomatic
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #4 on: July 23, 2009, 07:43:02 PM »
I enabled autologin, but skipped the ubuntu boot screen, etc.  It's all in verbose mode in text.  Like you, I still have the arrow displayed very briefly, but I live with it....
Wah!Cade is great for Linux users and Andy is very good at releasing frequently and fixing bugs...
Logged
bloodyviking77
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #5 on: July 31, 2009, 06:01:44 AM »
do you need to be running gdm? if you're going straight into X then I would have thought gdm is unnecessary and you could just "startx" with wahcade set to run in your .xsessions file?
I'm actually in the process of (maybe!) changing my cab over from a framebuffer/SDL only setup to run X (mainly so I can run zinc as well as mame - its a slow CPU!).
Whats been holding me back (other than lack of time and a dodgy ethernet cable that needs replacing) is managing the X session appropriately. I don't really want a heavy window manager so have been looking at ratpoison and awesome ... but initial tests haven't been very encouraging (squashed windows and generally crappy appearance). blackbox is next on the list to try ...
Logged
Shut up! Bloody Vikings!!
boxman
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #6 on: July 31, 2009, 06:26:37 AM »
Aha! I knew there would be a better way, thanks! If wahcade ever works without a window manager this will be perfect but for now I will be loading openbox then wahcade.
I tried blackbox but it seemed to load a bit slower than openbox, plus it has that bar on the bottom too. Pekwm might be good for this purpose but I haven't tried it yet because openbox works ok.
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.114 seconds with 22 queries.
