Author Topic: Dual - seamless LCD monitors?  (Read 3634 times)
november
  • Last login:January 24, 2011, 01:59:42 pm
« on: July 16, 2009, 06:13:55 pm »
This crazy idea came to me, but what about 2 widescreen LCD's places on top of each other?
I'm thinking it wouldn't  be as good as my mind wants it to be but it's an idea, still....
I know many people build arcades with proper monitors to relive the old times etc etc and I wouldn't mind doing that as well.....but the LCD just looks so damn clear.
I wish I could find a 25'' 4:3 monitor but I don't think they've ever existed.
I currently have a dynamo Street Fighter Cab that used to house a 25'' CRT arcade monitor.
Are there any other alternatives to this?
CRT pros
nostalgiac and proper arcade feel.
cons
heavy
old
not as clear
not LCD
Thank you in advance.
« Last Edit: July 16, 2009, 08:29:10 pm by november »
-Nic Ballarini
Ultimate PC
patrickl
  • Yo momma llama
    • PocketGalaga
Re: Largest Standard 4:3 LCD Monitor?
« Reply #1 on: July 16, 2009, 06:31:24 pm »
A CRT screen has a smaller usable diagonal than the size of the tube. That 25" CRT is probably comparable to a 22"or 23" LCD (if those actually existed).
november
« Reply #2 on: July 16, 2009, 06:38:36 pm »
---fudgesicle--- ---fudgesicle--- ---fudgesicle---, figs the tab sequence, lol.
Anyways I'll retype again.
I use a 19'' 4:3 LCD and it's okay(not big enough like 24.5 arcade monitor).
I could buy a 25'' 16:9/10 LCD and put it vertical in the cab but then the horiztonal games won't look very good.
So this is my impasse currently.
Do I just get the arcade monitor for the big images or get an LCD which is cheaper/easier to replace blah blah blah
-Nic Ballarini
Ultimate PC
november
Re: Dual - seamless LCD monitors?
« Reply #3 on: July 16, 2009, 08:28:36 pm »
what about dual widescreen-seamless LCD monitors?
Is this stupid or what?
Edited original post above.
-Nic Ballarini
Ultimate PC
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« Reply #4 on: July 17, 2009, 12:04:26 am »
I thought about this a long time ago, but feared the seam would be too noticeable. I'm waiting for someone to prove me wrong...
Blanka
« Reply #5 on: July 17, 2009, 03:22:37 am »
I use a 26 inch 16:10 LCD, and that's about the same visible area as a 24 inch 4:3 CRT and slight less than 19 inch vertical (but most vertical 19 inch screens were mounted deep in the cabinet).
november
« Reply #6 on: July 17, 2009, 11:46:40 am »
Can you give me the dimensions?
Suzo Happ has a 26'' LCD I can use.
24.8 arcade monitor is about 23.00 wide x 20.63 tall.
And the suzo 26lcd is 22.67 wide x 12.77 tall.
It's not a horrible difference but you lose almost 8 inches of height.
Is yours similar to the one sold on happcontrols.com?
I really would love to fill nearly the WHOLE void with screen lol.  I love big screens.
-Nic Ballarini
Ultimate PC
november
« Reply #7 on: July 17, 2009, 11:45:20 pm »
Just made the plunge.
I ordered a W2753V-PF - it's an LG 27'' monitor.
Should be a tight fit width wise but has decent demensions without stand:
Set without stand (WxHxD)25.7” x 18.6” x 3.5”
So it's fairly close to an arcade monitor and I'll figure out if I want it vertical or horizontal.
I can't wait for it to come in.
-Nic Ballarini
Ultimate PC
BORIStheBLADE
« Reply #8 on: July 18, 2009, 10:38:18 am »
Nice! are you planning on mounting it the way it is or taking apart and putting just the screen up?
november
« Reply #9 on: July 18, 2009, 01:12:32 pm »
I'm not 100% certain yet.  I'm thinking I'll have to take off the bezel to make it fit anyhow but maybe there's a way that I can get it to rotate(but I doubt it).
It's still not as tall as an arcade monitor but it'll have to do.
It's also more expensive hahah, so maybe I'm a fool.
Either way it'll be large and crisp and I can play some horizontally wide games, too :)
-Nic Ballarini
Ultimate PC
Blanka
« Reply #10 on: July 20, 2009, 04:19:55 am »
It is 551x344mm (21.7 x 13.5 inch) visible.
The 19 inch screens were like 366mm (14.4 inch) vertical (visible picture). So that is about 1 inch less.
Guess the Happ is a 16:9 screen, those are 324mm (12.8 inch) tall.
That is the worst ever application of Pythagoras law  ;D!
A 24.8 inch arcade monitor with 24 inch visible image means a 488x366 mm picture (19.2 x 14.4 inch). Exact the same a 19 inch monitors mount vertical.
The W2753V-PF  is 16:9 as well, so 336 mm tall (13.2 inch), and it is TN, so not the best viewing angles.
It is also not the fastest (problem of all >23 inch TN displays), with a 22ms lag.
Here you can see the measurements of its European cousin:
http://www.digitalversus.com/duels.php?ty=6&ma1=35&mo1=464&p1=4589&ma2=322&ph=12
It's TN, so vertical is no option.
« Last Edit: July 20, 2009, 04:36:24 am by Blanka »
november
« Reply #11 on: July 20, 2009, 09:01:39 am »
You're saying it should be 14.4 inch but the screen itself is 20.63 tall at the edges of the tube.  I don't see how it can be 14.4 inch viewable.
Doesn't make too much sense but I understand the math you're referring to.  Maybe my eyes are playing tricks on me lol.
-Nic Ballarini
Ultimate PC
Blanka
« Reply #12 on: July 21, 2009, 03:04:27 am »
Measure the diagonal then. Can't be 24.8 inch. That one must be larger, more like 31 inch diagonal then.
november
« Reply #13 on: July 24, 2009, 01:04:10 pm »
I must have incorporated the mounting hardware into that height :(.
Anyways, I cancelled the order on the monitor and will wait until I do more research.
I will try to never order something that's $400 when I'm really tired haha.
-Nic Ballarini
Ultimate PC
BASS!
  • Just have fun.
« Reply #14 on: July 25, 2009, 05:11:40 am »
Yeah buy a crt. Better for gaming all around.
