Author Topic: have a wells gardner 9001 problem cap kit volts are lower on new caps  (Read 1952 times)
arcade1213
  • Last login:July 27, 2009, 12:08:27 pm
have a wells gardner 4901 problem which is that i ordered a cap kit for a 4900 series board and the voltage on some caps are lower on the the new caps and higher on the old caps is this ok also the 4901 board looks slightly different than the 4900 board.
Kevin Mullins
    • Me on Myspace
Compare the questionable caps to what the manual parts list AND schematic says.
I have seen higher voltage caps installed but the manual called for the lower voltage included in cap kits. Go with the manual when in absolute doubt.
http://arcarc.xmission.com/PDF_Monitors/Wells%20Gardner%2019k4901%2019k4906%2019k4951%2019k4956.pdf
arcade1213
thanks for the link to the manual that helped alot and i have determined that the voltage on the caps on the board is the right voltage.i guess my question is now where can i find a cap kit for a wells gardner 4901,i could order from mouser but im looking for one already put together.thanks
arcade1213
any ideas as to my problem, i was always told that you could go up in voltage but never down in voltage and that uf rating has to stay the same this is true right?
arcade1213
any ideas as to my question above?
thanks for your time and have a nice day
Kevin Mullins
    • Me on Myspace
You are absolutely correct.......
Voltage can be HIGHER, but never lower.
uf rating MUST be an exact match.
arcade1213
thanks for your response and help,it helped me alot
SirPeale
  • Green Mountain Man
This should be a K4900 cap list in its entirety.
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=77A2F72D7F
I have other Mouser cap lists too.
