Author Topic: Mamewah and pc games  (Read 3836 times)
rbarr110
  • Last login:January 28, 2026, 12:10:10 pm
  • I already built my own arcade controls!
« on: July 15, 2009, 06:26:35 pm »
I'll admit it, I looked/searched a little, but got lazy and am taking the easy route...
How do I launch a PC game from Mamewah, I have had a copy of X-wing vs Tie fighter laying around for years and have never played it.  It looks kinda fun and seems like a decent arcade machine game.
Anyone do it?  PC games launched from Mamewah.
King Nerd
  • Last login:August 19, 2009, 12:12:04 pm
  • Putting the romance back into techromancer.
Re: Mamewah and pc games
« Reply #1 on: July 15, 2009, 09:12:38 pm »
Make the INI file look for "roms" with a "lnk" extension?
Lookin' for: Neo-Geo MVS x4 board, memory card reader, memory card, credit LEDs
MVS wants: Metal Slug (any), King of Fighters 2002, Puzzle Bobble (any), Rage of the Dragons, SNK vs Capcom, Magical Drop  (any).
zorrobandito
  • Last login:October 04, 2025, 12:11:09 am
    • Zorro's Classic Games
« Reply #2 on: July 16, 2009, 08:25:30 am »
King Nerd is correct. Make a batch file in each game dir, make a shortcut to it and drop it in the root of your PCGames dir - [emurootpath]\[emuname]
e.g.
Timeshock.bat
closemul.exe Timeshock.exe
You'll need a go.bat as a parent batch file to run each lnk.
go.bat
@echo off
%1 /wait
### 21pcgames.ini (mamewah v1.62) ###
emulator_title                            PC Games
### List Generation Settings ###
rom_path                                  [emurootpath]\[emuname]
rom_extension                             lnk
dat_file
nms_file                                  [emurootpath]\[emuname]\pcgames.nms
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      [emurootpath]\[emuname]\go.bat "[rompath]\[name].[romext]"{dosbox}{safelaunch}
post_emulator_app_commandlines
general_app_commandlines
« Reply #3 on: July 16, 2009, 09:13:37 am »
Actually you can just set:
rom_path                                  c:\put_your_lnks_here
rom_extension                             lnk
emulator_commandline                      pc
Mamewah will launch the target of the Windows shortcut (lnk) files.
zorrobandito
« Reply #4 on: July 16, 2009, 07:22:48 pm »
rom_extension                             lnk
Minwah, is that command line a MAMEWah feature or something even more arcane?
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #5 on: August 18, 2009, 01:27:34 pm »
rom_extension                             lnk
^^ this makes mamewah hang, then next time I launch mamewah, it crashes my machine. Tried this with v.1.63, 1.65 and 1.68 :(
EDIT: well, it works if I do not rename the shortcuts. I.E. "shortcut to ether vapor.exe" .... but, is there any way around this; can I rename the shortcut and still have mamewah launch it?
« Last Edit: August 18, 2009, 02:18:48 pm by TelcoLou »
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
massive88
« Reply #6 on: August 19, 2009, 11:05:23 am »
Ive renamed mine and they all work just fine.  Whats the log giving you when it crashes?  Have you refreshed the gamelist or are you not able to get that far?
TelcoLou
« Reply #7 on: August 19, 2009, 01:47:52 pm »
Thanks for the reply :) Here's mamewah launching fine (without re-naming the shortcuts):
Code: [Select]
8/19/2009 1:31:59 PM MAMEWAH v1.63 launched
8/19/2009 1:31:59 PM Cursor scheme: Windows Default, Arrow: (None), Wait: (None), AppStarting: (None)
8/19/2009 1:31:59 PM Desktop colour: 0
8/19/2009 1:31:59 PM Wallpaper filename:
8/19/2009 1:31:59 PM Desktop display mode: 1024x600 @ 60Hz, 32bit colour
8/19/2009 1:31:59 PM Decimal symbol: '.'
8/19/2009 1:31:59 PM Games list read: doujin-0.lst
8/19/2009 1:32:00 PM Mode 800 x 600 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
8/19/2009 1:32:00 PM Layout selected: C:\mamewah163\config\doujin\\layout.lay
8/19/2009 1:32:00 PM No. joystick devices attached: 0
8/19/2009 1:32:00 PM Ctrlr file selected: C:\mamewah163\config\mamewah.cfg
8/19/2009 1:32:00 PM Keyboard enabled
8/19/2009 1:32:06 PM List generation started...
8/19/2009 1:32:06 PM List generation finished
8/19/2009 1:32:06 PM Games list read: doujin-0.lst
8/19/2009 1:32:51 PM Mode 1024 x 600 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
8/19/2009 1:33:03 PM MAMEWAH quit
And here, after re-naming the shortcuts:
Code: [Select]
8/19/2009 1:34:37 PM MAMEWAH v1.63 launched
8/19/2009 1:34:37 PM Cursor scheme: Windows Default, Arrow: (None), Wait: (None), AppStarting: (None)
8/19/2009 1:34:37 PM Desktop colour: 0
8/19/2009 1:34:37 PM Wallpaper filename:
8/19/2009 1:34:37 PM Desktop display mode: 1024x600 @ 60Hz, 32bit colour
8/19/2009 1:34:37 PM Decimal symbol: '.'
8/19/2009 1:34:37 PM Games list read: doujin-0.lst
8/19/2009 1:34:38 PM Mode 800 x 600 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
8/19/2009 1:34:38 PM Layout selected: C:\mamewah163\config\doujin\\layout.lay
8/19/2009 1:34:39 PM No. joystick devices attached: 0
8/19/2009 1:34:39 PM Ctrlr file selected: C:\mamewah163\config\mamewah.cfg
8/19/2009 1:34:39 PM Keyboard enabled
8/19/2009 1:35:00 PM List generation started...
8/19/2009 1:35:00 PM List generation finished
8/19/2009 1:35:00 PM Games list read: doujin-0.lst
8/19/2009 1:35:37 PM Mode 1024 x 600 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
8/19/2009 1:35:50 PM MAMEWAH quit
Note: the laptop I'm testing this on has a screen res. of 1024x600, but this behavior happens on my cab setup with a CRT monitor as well.
Strange thing; if I re-name the shortcuts to, for example: "EtherVapor.lnk" they work just fine .. anything else, and the system slows to a crawl, and when I try to launch a game, it hangs and dumps me back to mamewah, and everthing is super-slow until I exit mamewah.
I also tried setting the folder to "hide known file extensions" and same thing happens.
Running WinXP home, on both the laptop and the PC in my cab.
... very strange indeed ...
TelcoLou
« Reply #8 on: August 27, 2009, 10:09:12 pm »
Update: If I name the shortcuts to ie: "Blue Wish ressurrection.exe" it also works (which looks nicer than 'blabla.lnk')
If I leave out the ".lnk" or ".exe", it causes mamewah to hang, then windows crashes when I try to exit.
Any ideas why? It's not the end of the world, but it's driving me mad, like a tiny splinter in the back of my brain  ;D
