Author Topic: X-Arcade  (Read 5666 times)
PCMedics
  • Last login:September 22, 2013, 12:28:12 am
X-Arcade
« on: July 14, 2009, 05:15:05 pm »
Hi I have my X-Arcade joystick working properly in Mala I believe . But when i use Mala to open snes I can not seem to make it work there any help or pointers ?  :banghead: Thanks Tom
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: X-Arcade
« Reply #1 on: July 14, 2009, 06:08:11 pm »
Which SNES emulator are you using? Does it work when you run the emulator manually (that is without Mala)?
PCMedics
Re: X-Arcade
« Reply #2 on: July 14, 2009, 07:08:25 pm »
Zsnes is the emulator I can program the controller in it but does not really work right . When i program them they show right in the input screen but then you load a game many of them start to turn on and off background sprites and displays in it.. This is the same thing that got me off maximums arcade i can always seem to get Mame emulated right but if i try to add others like Nintendo and Sega and game boy I run in to issues. I hope that makes sense?
SGT
Re: X-Arcade
« Reply #3 on: July 14, 2009, 07:45:00 pm »
I am not really following.  Mala does not have anything to do with how Zsnes interacts with your X-Arcade joystick or what sprites display or not.  You said that just like with Maximus you are able to get Mame running fine, but other emulators have issues.
Mala just provides a menu system to start up a Zsnes session.  It doesn't resolve issues you're having with the emulator itself.  It is usually necessary to first get the emulator setup and running satisfactorily by itself before
attempting to run it from a front-end such as Mala.
Sorry if I misunderstand the issue, but have you been able to get Zsnes running correctly WITHOUT Mala being part of the scenario.   Until you get it running correctly in full screen by itself, there's no need in trying to get Mala (or Maximus Arcade) to run it.
PCMedics
Re: X-Arcade
« Reply #4 on: July 15, 2009, 12:55:29 pm »
I will try to explain better. When I set up Znes i can map all the keys in the program it self to the tankstick in Znes. But when I start the emulator the  keys I have mapped start doing odd things like turning off backgrounds and sprites.There is very little customizing i can do in Znes it self regardless of if i open it from mala or the program it self.
SGT
Re: X-Arcade
« Reply #5 on: July 15, 2009, 05:43:29 pm »
I think I would post the question here:
http://board.zsnes.com/phpBB2/
PCMedics
Re: X-Arcade
« Reply #6 on: July 15, 2009, 06:26:03 pm »
Thank you
dafelandry
  • Last login:March 21, 2012, 12:08:40 pm
Re: X-Arcade
« Reply #7 on: July 21, 2009, 03:53:41 pm »
FIRST POST...
Well whats happening is that the buttons (i belive player 2 and a few player 1) are mapped to the top row of numbers on your keyboard... these number buttons are triggering hot keys set in Zsnes.... basically your backrounds are disapearing because the button you are pressing on your joystick are hotkeyed to remove sprites and such... a simple fix is to go to "MISC" tab and open "misc keys" and remove EVERY hot key!!! 100% this is whats wrong
SGT
Re: X-Arcade
« Reply #8 on: July 21, 2009, 10:57:21 pm »
That makes sense.  Good first post.  :applaud:
