Author Topic: CP graphic adhesive  (Read 2173 times)
Trebeck
  • "The Arcade" - Build #4
CP graphic adhesive
« on: July 09, 2009, 10:58:54 pm »
Hey all,
Well I messed up my new CP graphic.  After a few days I got little air pockets appear. Especially around the button and stick cuts.  I can smooth them out but they'll appear in a few hours again.
So my question is, can I peel it off and use something stronger?  And what product can I use on vinyl?  I went to the Home Depot and most of them said not to use on vinyl.
BASS!
  • Just have fun.
Re: CP graphic adhesive
« Reply #1 on: July 11, 2009, 09:11:04 pm »
Just grab a very sharp sewing pin, and poke in an inconspicuous area. *black areas are the best, then just use a sharpie, and give it a little rub with your finger.
Trebeck
« Reply #2 on: July 13, 2009, 11:39:06 pm »
Well the lifts are all connected to the holes cut for the joysticks and the buttons.  I can push the air out completely but it will lift over a day or so.
Any ideas?
« Reply #3 on: July 14, 2009, 01:11:03 pm »
Did you use a burnishing tool to apply it?  Try going over it again with something like that after punching the tiny holes like BASS! suggested.
