Author Topic: (SOLVED) Switching Power Supply keeps tripping all of my breakers!  (Read 1377 times)
oldgamesrbetter
  • Last login:August 31, 2024, 09:30:07 am
  • You weak pathetic fool!
http://www.jammaboards.com/store/15a-arcade-switching-power-supply-110w/prod_251.html
This is the power supply i'm using.. I have nothing else hooked up to it.. its just the power supply.. and the sepereate plug...i stripped the ends of the plug and put it under the AC screw.. tried both ACs.. and it shorts my breakers every time! I even put it on the lowest setting. Am i hooking it up right? I'm a noob please help.
EDIT 6/7/09:
I had both ac wires of the plug hooked up to the same ac screw of the power supply... im retarded lol. Works like a charm now. Don't do what i did! haha.
« Last Edit: July 09, 2009, 06:32:16 am by oldgamesrbetter »
BobA
  • What Me Worry?
Re: Switching Power Supply keeps tripping all of my breakers!
« Reply #1 on: July 08, 2009, 05:08:31 pm »
If it is not automatic voltage selection make sure you have selected the proper input voltage 110 or 220 depending on where you are.  If you have your AC wires on the right terminals and you have your input voltage set correctly then you probably have a defective PS.  Only other possibility might be a short in the plug/wire that you attached.
oldgamesrbetter
« Reply #2 on: July 08, 2009, 08:56:00 pm »
Solved. Look at top post.
« Last Edit: July 09, 2009, 06:32:52 am by oldgamesrbetter »
