Author Topic: Split screen on Arcade Monitor  (Read 6667 times)
djbubba2002
  • Last login:April 09, 2010, 01:19:31 pm
« on: July 07, 2009, 07:17:48 pm »
First off , I was readin alot on here .. did diff things and still i am gettin a slip screen ..
I got a mortal kombat 3 arcade
video card brand : IntelR
t.v model is 25k7193
I got a J-PAC to hook up mame to it .. i did all of the jumpers 15 and 31
1. I tested out the Soft 15khz and that didnt work for me ...
2. I tested Powerstrip with 640x480 resolution and now I got a slip screen
am i missing something on windows xp or something .. if anyone can help , thankyou ...
Kevin Mullins
    • Me on Myspace
Re: Split screen on Arcade Monitor
« Reply #1 on: July 07, 2009, 07:28:57 pm »
You are still putting out 31khz....... needs to be 15khz and a lower resolution.
djbubba2002
« Reply #2 on: July 07, 2009, 07:38:43 pm »
thanks for the post .
Can you tell me how to fix this ....
640x480 resolution and now I got a slip screen . Do i have to go lower then that ?
how can i change the 31 to 15khz
technocop
  • Last login:November 03, 2009, 04:55:45 pm
« Reply #3 on: July 08, 2009, 04:48:02 pm »
I am having the exact same problem.
I am running soft15 through a JPAC interface. Soft15 has installed OK, and I can run my arcade monitor at 640x240 no problems, but when I select 640x480 I get the exact same problem.
It is NOT because I am sending a 31Khz signal, the JPAC sync light is active, informing me that it is recieving a 15KHz signal.
Can anyone tell me what I might be doing wrong? why can't I get 640x480 interlaced working. MIght it be my monitor doesn't support it (It's a hantarex polo 20")?
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: July 08, 2009, 06:35:58 pm »
No,  you ARE running 31khz... that LED will light up as long as the JPAC is OUTPUTTING a proper sync,  which it is doing and why you see 2 screens.
Here's a quote from the Ultimarc site:
Constant "split screen" (one vertical split down the middle with 2 pictures, one each side). This means you have not configured MAME or ArcadeOS for 15Khz and the PC is still sending a normal VGA signal. The J-PAC is operating in "scan divide" mode. To verify this is happening, try running with only the 15Khz jumper on. This will disable the J-PAC "scan divide" mode and the green LED will go out, indicating that the sync is out of range.
I'd recommend you go read the FAQ there:  http://www.ultimarc.com/jpac2.html
Bottom line is you need to properly configure SOFT15KHZ or get an ArcadeVGA video card.   Nothing else will fix this problem... and that's the answer for both of you folks...
djbubba2002
« Reply #5 on: July 08, 2009, 07:14:51 pm »
 I am not using soft15khz , I am using Powerstrip,
You said configure mame and This means you have not configured MAME or ArcadeOS for 15Khz .
How do you do that ..
FrizzleFried
    • Idaho Garagecade
« Reply #6 on: July 08, 2009, 07:36:18 pm »
Then powerstrip isn't properly configured.  The bottom line my friend is that you're still pumping 31khz in to the JPAC...
I am unfamiliar with powerstrip so i can't help you there,  but there is a big sticky here on this forum.  I use soft15khz and at least with me it was pretty much run and go...
djbubba2002
« Reply #7 on: July 08, 2009, 07:51:32 pm »
i was reading everything ... now i am loses...hehheh
say if i buy a vga card .. that is the only thing i need and it will do the job..... fix my screen .. i dont have to mess with 15khz and 31 khz then ... or mame...
You are sayin .. VGA CARD will fix everything ..in one shot .....
If i got it on the screen, and it is slip ... that has to be a way to fix becuase i have it on the screen and its not right ,, but there should be a way ...., and not go out and buy a new video card....
what mame should i use to run  mameplus for it ....
« Last Edit: July 08, 2009, 07:57:50 pm by djbubba2002 »
Kevin Mullins
    • Me on Myspace
« Reply #8 on: July 08, 2009, 08:28:35 pm »
Now ya'll are starting to get the idea.
An "arcade" monitor i.e. a CGA monitor has a maximum capability to work with.
For instance on the 25K7193 the other fella has.
http://www.wgec.com/pdf/Spec/K7000.pdf
Graphics modes: 640 X 200
They have limitations........period.
So what tends to happen is people will slap 640x480 up there thinking that is LOW, but in all actually you're still sending DOUBLE the horizontal that the monitor is native capable of. (the 480 part)
DOUBLE the resolution - DOUBLE image. (more or less anyways)
31khz is nearly DOUBLE 15khz - DOUBLE image. (more or less anyways)
Too high a resolution is just gonna make it wonky regardless of what you try.....except for going LOWER.
Kinda get the idea here?
And when in doubt.... read the Wiki at the bottom of Ummons signature.
(just kidding)
« Last Edit: July 08, 2009, 08:32:46 pm by Kevin Mullins »
SirPeale
  • Green Mountain Man
« Reply #9 on: July 08, 2009, 08:39:10 pm »
The question is: does the video chipset in this machine support a proper 15KHz?  The PC I'm typing on right now "technically" supports 15KHz, but even with tweaking I couldn't get it to display correctly.  Now it's my wife's PC.
djbubba2002
« Reply #10 on: July 08, 2009, 10:36:36 pm »
I have to look in the booklet .. to see if it is a proper 15khz ..
why do you have the samething ?
I should go with 640x200 then ..to see if that does it ..
technocop
« Reply #11 on: July 09, 2009, 04:40:12 am »
OK - now I'm confused
FrizzleFried - what you're saying makes sense. If I'm still sending a 31Khz signal, it would obviously explain why I am getting a split screen. (I assume the monitor is not capable of "splitting" the signal itself?)
Kevin Mullins is going on about how my monitor might not support 640x480, but if I'm still sending a 31Khz signal, that is been split by the JPAC, how do I know my monitor doesn't support it? The signal isn't getting there! You can't both be right.
FrizzleFried - you mention "properly configuring" soft15. As far as I can tell, you just install it. I don't think there's any additional configuration (is there?)
I'm using a Nvidia 6600GT, which i believe is on the supported list for soft15, but maybe it doesn't quite work properly? It works at 640x240, but maybe it doesn't provide an interlaced signal at 640x480??
Any more help would be appreciated, I'm close to giving up. But I would at least like to know WHY I can't get this working.
(Please don't patronise me by telling me to "read the wiki" or something. I've read everything I can find)
cheers! :cheers:
FrizzleFried
    • Idaho Garagecade
« Reply #12 on: July 09, 2009, 10:19:23 am »
cheers! :cheers:
Kevin was wrong about your monitor not supporting 640x480... it does... in interlaced mode (as opposed to progressive).   I am not sure why you're having issues at 640x480,  I'd suggest you read through the Soft15KHZ thread.
I know I have issues at certain resolutions that ArcadeVGA had no problem supporting...
Kevin Mullins
    • Me on Myspace
« Reply #13 on: July 09, 2009, 11:18:59 am »
Kevin was wrong about your monitor not supporting 640x480... it does... in interlaced mode (as opposed to progressive). n resolutions that ArcadeVGA had no problem supporting...
Ah .... see, I didn't know about the Hantarex capabilities and I simply don't get into it all that deep for the mame stuff.
(interlaced, progressive, yada, yada)
My point being is that was where they needed to look.
Hope they can both get it situated.
djbubba2002
« Reply #14 on: July 09, 2009, 11:32:50 am »
i am getting a full screen now and , its goin up and down willy fast ...heheheh
this is at 640x480i     ...... this is killin me ..
I have someone on my computer , logmein .. fixing it for me ..now .. they cant get it to work ..yet ..
There is Two Green lights on the J-PAC chip now .. is that good or bad
« Last Edit: July 09, 2009, 11:36:20 am by djbubba2002 »
FrizzleFried
    • Idaho Garagecade
« Reply #15 on: July 09, 2009, 11:59:08 am »
...adjust your vertical hold.
djbubba2002
« Reply #16 on: July 09, 2009, 12:16:42 pm »
I dont want to be dumb now , but what is that ?  lol
« Last Edit: July 09, 2009, 12:18:16 pm by djbubba2002 »
Kevin Mullins
    • Me on Myspace
« Reply #17 on: July 09, 2009, 01:08:23 pm »
Yes, as with ANY true arcade monitor you will have to expect to do some "physical" adjustments on the monitors itself.
i.e. - All those knobs and things you find on the backside of the monitor.  ;)
http://www.wgec.com/pdf/Board/K7000_13_19_25_and_27_inch.pdf
djbubba2002
« Reply #18 on: July 09, 2009, 01:09:52 pm »
i got six of them in the front of the cabinet .. here  is a pic now ..
it is still not right yet , but we are gettin closer..now ..
« Last Edit: July 09, 2009, 02:04:08 pm by djbubba2002 »
Kevin Mullins
    • Me on Myspace
« Reply #19 on: July 09, 2009, 03:12:00 pm »
Yeah, I didn't think to mention the remote board if you have one.  :cheers:
Definitely getting closer.... one thing to keep in mind is don't get stuck judging it by how "Windows" looks, take a look at your FE and games and such as well.
Jack Burton
« Reply #20 on: July 09, 2009, 03:13:11 pm »
Looks like your H and V positions are off a little bit.  Sometimes if the screen is over to one side too much you'll get that transparent overlaying effect.
djbubba2002
« Reply #21 on: July 09, 2009, 03:19:35 pm »
thanks guys ,, you are big help , and i thanks you .. i am still workin at it ...
1. is dont look at windows right ?
2. Opne up advance mame to see how it looks right ?
3. or should i go out and buy a good video card , and i wont have this proablem .. will i
« Last Edit: July 09, 2009, 03:22:13 pm by djbubba2002 »
