Author Topic: Paint advice in UK  (Read 1170 times)
korbitz
  • Last login:June 30, 2017, 01:09:54 pm
Paint advice in UK
« on: July 07, 2009, 05:28:42 pm »
For all you UK cab builders out there, may i ask what paint/s you have used on the finish of your cab, and can you provide a link to a supplier. I have looked at various local DIY stores and tbh there range is pitiful. I know that the book says latex semi-gloss, is that what it is called in the UK or is that a US term, google doesn;t really provide many options.
Cheers in advance
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Paint advice in UK
« Reply #1 on: July 07, 2009, 07:07:41 pm »
One of the better options for MDF is to use a durable outdoor weathershield intended for wooden exterior doors. You will not need primer as the paint goes on thick (though you will need several coats), plus it makes the surface less porous (so more resistant to water spillages), the finish can be amended based on the number of coats you use (2 for matt, 3 for semi-gloss, 4+ for gloss) and it is easy to apply (foam roller for best finish). Sadolin make an 'ebony' colour of this paint and it is readily available at most garden centres:
Doesn't matter whether you use the standard (pictured), the 'extra durable', or the one coat (red tin) stuff, though they do cure at slightly different rates (original tacky after 6 hours, 'one-coat' tacky in about 3 hours) and it is best to leave 24 hours between coats. It's quite pricey at around £30 a tin, but you can do 3 coats on 2 full-size uprights using 1 tin, so works out to £15 a machine. This is very similar to what we use on our machines (though we use a bulk-buy paint) and we have used this on full machines in the past and as a touch-up paint for our cabinets:
« Last Edit: July 07, 2009, 07:10:35 pm by Turnarcades »
korbitz
« Reply #2 on: July 07, 2009, 07:35:26 pm »
Thanks for the reply..
Cpl points, i have already undercoated the mdf, will that make any difference?
Also, are you basing the coverage on a 2.5ltr tin or the 5ltr tin?
Cheers again
Turnarcades
    • Turnarcades
« Reply #3 on: July 07, 2009, 09:14:08 pm »
2.5l. Undercoat shouldn't make much difference, but you may want to go read a tin first to be sure.
