Author Topic: FS: 27" CRT VGA/COAX/SVID w/ speakers/Tuner MICH/USA  (Read 3086 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: July 06, 2009, 12:56:53 pm »
Looking to sell 2 at the moment. 27 inch look like tv's by the caseign but they accept coax/vga/svid. cant recall if they take composite. they have built in speakers and have full controls for picture adjustment. The case is black in color. Feel free to stop nad check them out. Looks like the max vga res is 800x600 but unsure  due to the crappy laptop i hooked up to test them on.
Unit are dated 1999.
Would make a great monitor!!! Make an offer if interested. I have a number in mind, lets work something out!!!
northerngames
  • Trade Count: (+18)
Re: FS: 27" CRT VGA/COAX/SVID w/ speakers/Tuner MICH/USA
« Reply #1 on: July 06, 2009, 07:49:51 pm »
I may be interested but with no make or model number or pics I have no number in mind and would preffer to hear yours instead :lol
something like this I also would need to know where at in michigan as gas may cost more then the monitor these day's.  :cheers:
delta88
« Reply #2 on: July 07, 2009, 04:06:59 pm »
Prolly looking to get 1 million billion for them ;)
I am located in Plymouth. 48170
If your not to far I can even toss one or two in the back of my car and drive them over.
As for brand and model number they arent anything mainstream from what I can tell. mega something, mondo, monster,... something with an M. :dunno
I figure its a LARGE crt that accepts everything. whats it matter what brand it is. No goiong for HD or anything. Just arcade quality, actually a little bit better :) :applaud:
northerngames
« Reply #3 on: July 07, 2009, 04:29:35 pm »
I just wanted a make and model to search it to find out what all it can do and handle display wise and also what H & V sync types it can accept.
I have a 26" nanao I am currenty running for true arcade quality as a vga cannot to them but if it also does 15K it makes a huge difference for me as I may swap the nanao out for one of these.
 I just need to know what I am getting into for sure is all and monitor specs are very important to me as that is what you looking at while playing  :D
Ummon
  • Trade Count: (+13)
« Reply #4 on: July 07, 2009, 05:48:12 pm »
Yeah, at least pictures, but any kind of model/serial numbers (usually close to date stamps - hint) would be good.
Yo. Chocolate.
Stephen Hawking
BASS!
  • Just have fun.
« Reply #5 on: July 09, 2009, 03:41:50 am »
Maybe Mitsubishi  Megaview
delta88
« Reply #6 on: July 10, 2009, 01:37:07 am »
Thats what it is. Megaview!!!
thx!!
northerngames
« Reply #7 on: July 12, 2009, 09:00:36 pm »
That helps a ton did you want to share that number in your head yet?  :angel:
delta88
« Reply #8 on: July 23, 2009, 10:54:57 pm »
northerngames
« Reply #9 on: July 24, 2009, 07:29:13 pm »
How much you asking for one?
delta88
« Reply #10 on: July 25, 2009, 10:27:24 pm »
PM's sent   :cheers:
padstack
  • Last login:February 03, 2024, 12:54:24 pm
« Reply #11 on: July 29, 2009, 01:45:50 pm »
pm sent
padstack
« Reply #12 on: August 08, 2009, 07:57:07 am »
2nd pm sent.  I'd like to pick one up next week.
padstack
« Reply #13 on: August 09, 2009, 02:47:33 pm »
I'm going to be in your area tomorrow and Tuesday.  Would like to pick one up Tues.  Let me know.
BASS!
  • Just have fun.
« Reply #14 on: August 09, 2009, 08:31:53 pm »
Cool monitors, but they don't do 15khz. Only 31-38 so no native rez stuff.
      CRT: 29" (27" viewable) Super Arch Mask (D.B.F.)
      VGA, VESA VGA, SVGA, 8514A
      Connector: 2 x 15 Pin D - Sub t
      Speaker: 12Wx2 + Sub-Woofer
      OSD function: Brightness, Contrast, V-Size, V-Pos, H-Size, H-Pos, Pincushion, Trapezoid, Bow, Parallel, Rotation, Moire, ON/OFF, VGA- Audio ½, Bass, Treble, Balance, Volume, Recall, 110/220 Vac /230W Max auto-switch
      Power management: EPA/VESA DPMS
      Plug & play: VESA DDC 1/2B (Opt)
      CRT dot pitch: 0.75 mm
      Max resolution: 800 x 600 ( NI )
      Hor.: 31.5 kHz - 38 kHz
      Ver.: 50-120 Hz
      Bandwidth: 48 mHz
      Monitor dimensions (in.): 28x23.5x20 (WxHxD)
      Packing dimensions (in.): 32x29x25.2 (WxHxD)
      Weight (net/gross lbs.): 103/123
      Hor. Freq: 31.5 kHz
      Ver. Freq: 50-60 Hz
      Definition: 6 mHz of video
      VGA Input: Analog RGB 15 D type
      Video Composite Sync (1.0VPP IN/OUT I S-VHS Input)
      Audio: RCA Jack for IN/OUT
      Panel Control: Power, CH+/-, Volume+/-, TV/AV TV/CAV, Auto Programming
      Remote Controls: Power, CH+/-, Volume+/-, TV/AV TV/CAV, Auto Programming, Contrast, Brightness, Color, Hue, Mute, System Timer, Sleep, Quick View, Volume, Flashback, NTSC/PAL/PAL-M/PAL-N/SECAM switching, Bilingual (SAP), Display, ADD/ERASE, toggle, Video adjustment, Fine tuning
      Connectors: Antenna (RF), S-Video, Audio in, Video in, Audio out, Video out, VGA out to monitor, VGA in from PC, Power & Signal connector
      Optional CT-1871 Visionbox for Video & TV
          o
            Channels: 181 full Channels
          o
            Close caption enable / disable
          o
            525 Line (NTSC) or 625 Line (PAL)
Ummon
« Reply #15 on: August 10, 2009, 06:29:43 pm »
Yes it can.
Ver.: 50-120 Hz
Yo. Chocolate.
Stephen Hawking
padstack
« Reply #16 on: August 10, 2009, 11:21:14 pm »
if delta88 is still around, I'd love to pick one up tomorrow.  E-mail me or pm me and I shoudl get it on my phone while @ work tomorrow.
padstack
« Reply #17 on: August 12, 2009, 11:04:06 pm »
WAnted to let everyone know that these are a great deal if ur local. I just got mine in (after some minor decasing since I screwed my measurements up). I have mine running n 640x480 right now (defaulted to 800x600) and IMO it looks great.  Easy transaction and a great monitor at a great price
