Author Topic: Need Quick Advice for Small paint job!!!  (Read 2664 times)
xxkodemanxx
  • Last login:August 18, 2012, 12:50:47 pm
« on: July 01, 2009, 09:54:08 am »
hey guys!
Ill be painting my Control Panel. It's a small job..like 2'x3'
its 3/4" MDF
Been reading around a lot and getting some mixed ideas..maybe depends on the size of the project..
But Im thinking this is what im going to do..and wanted to see if i was right.
*im using spray paint..not a gun :( it IS a small job*
*Sand The MDF with 600grit
*Use this Primer Spray: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100371323&N=10000003+90020
*Sand it off with 220?
*repeat twice
*Spray on 2-3 coats of black
Should i use Flat/Gloss/Semi?
and does that sound about right for the job?
I have future plans for a CPO..but this will have to due for now ;/
xxkodemanxx
Re: Need Quick Advice for Small paint job!!!
« Reply #1 on: July 02, 2009, 01:20:58 am »
please? lol
i plan on going by the Home Depot tomorrow (today)
just wanna make sure what im doing sounds about right
thanks!
orion
« Reply #2 on: July 02, 2009, 01:31:23 pm »
Well, you don't want to sand the primer completely off, but you do want to sand it as smooth as possible with the 220 and clean it with a tack rag between each coat. Most importantly, make sure the MDF is sanded as smooth as possible before you hit it with any paint. If your not particularly good at spay painting, then I would recommend going with the flat paint, as the gloss paint will show every imperfection in your paint job. Personally I try to avoid painting whenever I can.
xxkodemanxx
« Reply #3 on: July 02, 2009, 01:36:36 pm »
thanks for the reply!
thecheat
  • Last login:October 16, 2009, 11:58:55 am
« Reply #4 on: July 02, 2009, 04:38:58 pm »
It also might be easier just to get one of their tiny rollers and a pot of paint. They also sell these little plastic dodads that are flat with a synthetic fluff on the other side - sort of like a roller that has been cut and flattened. Rub it in some paint and it goes on VERY smoothly.
Here is a link for reference: http://paint-and-supplies.hardwarestore.com/47-347-pad-painters.aspx
dryseals
  • Last login:March 12, 2011, 10:30:24 am
« Reply #5 on: July 03, 2009, 11:29:00 am »
You want a sandable primer. Most can primer are not that way. In the automotive section of many stores you can find a fill and sand primer.
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #6 on: July 06, 2009, 11:45:30 am »
Put a half dozen coats of clear spray lacquer on after painting and it will look great and have some protection.
