Author Topic: keyboard encoder question...  (Read 807 times)
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« on: July 08, 2003, 12:08:12 am »
hey. i am making a jukebos control panel for my existing arcade, and i want to know if ipac2 or keywiiz can do this: i will program custom key layouts (both do) but i want to be able to unplug this, plug it back in, and have the same custom layout. can either of these do it? usb or ps2, i don't really care. thanks n advance
Jacob
It's all about the Pentiums
paigeoliver
  • Awesome face!
Re:keyboard encoder question...
« Reply #1 on: July 08, 2003, 12:15:58 am »
Yes, the I-Pac saves its programmed layout when unplugged. Mine hadn't been plugged up for months, but still remembered my custom programming when I tested it yesterday.
Now, if it would only remember how to make the Player 1 joyleft input work  >:( That input died a while back and doesn't work in either Mame or even when programmed.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: July 08, 2003, 06:53:24 am »
Jacob
I-PAC will remember the custom config.  KeyWiz will need the custom config reloaded, but you can do this from a batch file either in the autoexec.bat, or in a batch file to load the jukebox software.
