Author Topic: Total Wii Noob, where do I go from here?  (Read 9124 times)
crashwg
« on: June 21, 2009, 11:42:06 am »
So I got myself a Wii.
Apparently it has a WiiKey in it which I do not doubt because it came with a burned game in the drive that worked fine when I booted it.
I tried to play a newer game and it updated the system menu to Ver. 4.0U.
The Wii Menu contains The Homebrew Channel.
How do I go about making DVD backups of games so my kids don't destroy them?
I have no idea what I'm doing here and trying to sift through the information on the web is futile knowing as little on the subject that I do.
As of right now I do not want to do anything with USB HDDs or anything of that sort, just a simple rip and burn.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
crashwg
Re: Total Wii Noob, where do I go from here?
« Reply #1 on: June 21, 2009, 01:57:49 pm »
In before post hell.
Not quite sure what you think is wrong with my post but whatever...  I just want to know how to backup the investment that buying games has become in this day and age of optical media.
Lemme say it again
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #2 on: June 21, 2009, 09:37:04 pm »
USB HDD is THE way to go.  I set mine up over the past couple days and it is freaking awesome.
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #3 on: June 21, 2009, 10:53:03 pm »
The only ways that I know of to dump your Wii games is to use Wii DVD Dumper or to use WiiHDDLoader.  Wii DVD Dumper takes around 3hours to dump one game over a local network.  Now that they have HDLoader it is the fastest way to dump your games.  It only takes any where from 5 min to 30 min depending on the size of the game to dump it to your usb drive.  And then it only takes about 5 min for WBFS Manager to extract it from the hard drive to your computer for burning.
If you don't want to actually play the games off of the hard drive Fry's sells 8gb usb flash drives for around $20.
Red
  • Last login:November 07, 2017, 08:37:51 am
« Reply #4 on: June 22, 2009, 04:07:27 am »
You can also dump your Wii games using your computer or laptop with a Hitachi-LG GDR-8164B DVD Drive, which are available on eBay.
crashwg
« Reply #5 on: June 22, 2009, 01:20:37 pm »
So let's say I want to use WiiHDDLoader to dump the games.  How do I go about installing that on a Wii with system menu 4.0U if I already have the Homebrew Channel?
Lemme say it again
crashwg
« Reply #6 on: June 22, 2009, 03:44:17 pm »
You read the links in the other thread.
Ok, so I've followed a link from the other thread to HERE and the only thing I can find is setting this up from the beginning.  Do I have to start from the beginning or can I jump in in the middle somewhere after getting the homebrew channel up and running?
Lemme say it again
crashwg
« Reply #7 on: June 22, 2009, 05:25:32 pm »
Alright then.  So I started at step 3.
Step 3: CHECK
Step 4: CHECK
Step 5: Followed link and downloaded "USB Loader GX V1.0 (updated to r316)"
this file does not contain "USB Loader GX[version].wad"
Now I'm stuck
Lemme say it again
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #8 on: June 22, 2009, 09:20:58 pm »
You extracted the entire folder (the folder itself included) into the apps folder on the SD card, correct?
Then loaded the HbC, and selected the usbloader_gx?
If so, it should work.  If not, try the latest build, or waninkoko's or cover flow loader.
By the way, starting at step three, did you install DVDX and bootmii?  bootmii is apparently as a safeguard, and DVDX to read regular DVD media.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
Generic Eric
« Reply #9 on: June 22, 2009, 10:29:02 pm »
The website lifehacker.com has some good guides and links.
crashwg
« Reply #10 on: June 22, 2009, 11:04:32 pm »
If I extract the folder to the apps directory on my SD I can load the program from the HomeBrew Channel.  It will load up and say there is no USB HDD attached if I try either a USB to IDE adapter on a HDD or use a thumb drive that I have but that's a problem I'm going to try and work on once I get this installed...
What I'm trying to do is install the program "wad?" so that I will have a channel on my wii menu.
Lemme say it again
Blanka
« Reply #11 on: June 23, 2009, 07:26:27 am »
There is no need to backup stuff on a Wii. Games get boring way before the discs become unreadable. A Wii is a 2-month gadget, not a serious gaming machine.
« Reply #12 on: June 23, 2009, 12:23:09 pm »
Depending on your media and drive some can be glitchy.  I have a couple games that like to crap out at random times that would work a whole lot better off a hard disc.
hypernova
« Reply #13 on: June 23, 2009, 08:04:25 pm »
Opinion about the Wii noted.  Irrelevant to the situation.
crashwg, perhaps you could list what parts of step 5 you've gotten done?  Or perhaps it may be your HDD or flash drive.  I don't believe they are all fully compatible with the Wii.
spiffyshoes
« Reply #14 on: June 23, 2009, 08:54:27 pm »
Make sure you have it plugged into the correct USB port.  The new versions of the loaders only work with the Hard Drive plugged into the left USB port.
Check out this thread.
http://gbatemp.net/index.php?showtopic=114165
danny_galaga
  • Last login:Today at 06:15:47 am
    • dans cocktail lounge
« Reply #15 on: June 24, 2009, 05:56:47 am »
wow. this all seems so complicated. I think I'll just be careful with my wii games...
« Reply #16 on: June 24, 2009, 09:53:26 am »
He's right, the Wii is totally not a serious gaming machine.  It does require some prep time, though.  Takes me 20 minutes to get my clown makeup on every time I want to use it.
crashwg
« Reply #17 on: June 24, 2009, 02:28:39 pm »
I went out and bought a Western Digital My Book Essential Edition because it's the closest thing I could find to the list of "hardware recommendations" on THIS PAGE  Matter of fact it has the same model number other than being 500 GB rather than 1 TB.
I've plugged the HDD into my computer, created an unformatted partition and formatted a partition with WBFS Manager.  I plugged the HDD into the Wii and loaded up USBloaderGX from the Home Brew Channel and in either port is says "No USB Device."  I then tried waninkoko's SD/USB loader v1.5, pressed "A" when USB Mass Storage Device is selected and instantly this whole thing shows up:
Code: [Select]
Mounting device, please wait...
(30 seconds timeout)
ERROR! (ret = -1)
Press and button to restart...
By "left USB port" are you referring to the one nearest the top of the console when it's layed on it's side?
Lemme say it again
crashwg
« Reply #18 on: June 24, 2009, 03:37:39 pm »
Figuring that the problem was either USB ports just plain not working or a previous step not working for some reason I went back to step 4, installing cIOS and instead of installing the recommended 38 I used the 249 that it defaults to and everything works now.
Thanks everyone.
Lemme say it again
hypernova
« Reply #19 on: June 24, 2009, 07:37:42 pm »
Feel like this?   :banghead:
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #20 on: June 24, 2009, 10:46:58 pm »
 :laugh2:
Best Kid iPad Apps
skim36
  • Last login:September 03, 2015, 03:37:21 pm
  • "Where's the nearest restroom?"
« Reply #21 on: July 12, 2009, 01:25:55 pm »
Yes, 249 rev 10 is the most compatible.  I get all my info from wiihacks.com  A great place to start.
hypernova
« Reply #22 on: July 13, 2009, 06:29:49 pm »
I've found rev10 to be the best as well.  rev13 requires setting all the games to enable the error 002 fix.  I've only had to do that on two games with rev10.
