Author Topic: MINI MULTI GAME (BARTOP)  (Read 15503 times)
PCMedics
  • Last login:September 22, 2013, 12:28:12 am
Re: MINI MULTI GAME (BARTOP)
« Reply #40 on: August 02, 2009, 09:14:02 pm »
That looks great! Did you take pictures actually installing the hardware inside, the lcd the boards ?
PeteDiak
  • Last login:December 09, 2012, 10:02:42 pm
    • minimulti game
« Reply #41 on: August 03, 2009, 09:32:08 am »
I built the machine by myself, so i did not take pictures of the cab being put together. I can take a picture with the back off if you like.
Projects
Miss Pac Man Cocktail (Finished)
Mini Multi Game (Finished)
PCMedics
« Reply #42 on: August 03, 2009, 04:53:58 pm »
Sure that would be great thinking of going the way you did to make a bar top my self.
PeteDiak
    • minimulti game
« Reply #43 on: August 03, 2009, 07:54:00 pm »
I have more pics of the build here http://minimultigame.webs.com/apps/photos/album?albumid=5847334
I'm happy to answer ant questions you have..
Projects
PCMedics
« Reply #44 on: August 04, 2009, 10:53:55 pm »
Great web site documentation on your build. Tom :cheers:
PeteDiak
    • minimulti game
« Reply #45 on: August 04, 2009, 11:11:56 pm »
Thanks Bud glad you like it.. If you have any questions pm me your email and i will add you to my msn.. I am very happy to help..
Projects
PeteDiak
    • minimulti game
« Reply #46 on: August 07, 2009, 05:57:42 pm »
Here is a pic with the back off..
« Last Edit: August 07, 2009, 06:01:08 pm by PeteDiak »
Projects
PeteDiak
    • minimulti game
« Reply #47 on: October 10, 2009, 07:09:13 pm »
I tried painting the plexi glass to hide the gaps in the cab . I taped it off well and covered areas i did want to paint. It didn't work well . The paint bled threw the tape and got everywhere. Now I have to cut my plexi again..
Projects
Ginsu Victim
  • Comanche, OK -- USA
« Reply #48 on: October 10, 2009, 07:23:17 pm »
Did you spray it all at once in one thick coat or something? I've never had it bleed through like that by spraying in several thin coats.
IG-88
« Reply #49 on: October 10, 2009, 07:25:17 pm »
Not to pile on but make sure you use good painters tape. Worth the extra few bucks.
-HarumaN
PeteDiak
    • minimulti game
« Reply #50 on: October 15, 2009, 09:43:40 pm »
Maybe i did spray it on a little thick.. Also it wasn't the greatest painters tape.. I appreciate your suggestions and will try again this weekend..
Projects
PeteDiak
    • minimulti game
« Reply #51 on: October 17, 2009, 10:48:04 am »
I painted my plexi glass again today and it came out great!.. Thanks Ginsu Victum and IG-88 for the advice...
I installed the speaker grill and am officially finished.. Thanks everyone for all your help..
Pete Diak
Projects
IG-88
« Reply #52 on: October 17, 2009, 11:05:13 am »
Looks great!!   :cheers:  Did you do the better tape and thinner coats both then?
-HarumaN
PeteDiak
    • minimulti game
« Reply #53 on: October 18, 2009, 05:41:47 pm »
I applied thinner coats and used better tape.. It really helped
Projects
PeteDiak
    • minimulti game
« Reply #54 on: December 12, 2009, 11:04:27 pm »
Man this Bar Top is great.... :D
Projects
bigpete405
  • Last login:April 30, 2014, 07:48:03 pm
« Reply #55 on: December 28, 2009, 03:01:05 pm »
very good.  :cheers:
PeteDiak
    • minimulti game
« Reply #56 on: January 14, 2010, 07:16:20 pm »
Thanks  :cheers:
Projects
bigpete405
« Reply #57 on: January 23, 2010, 08:54:17 am »
 :applaud: I really like this bartop. I didnt read the discription until viewing it at least 5 times, and was wondering why the one I'm building looks slightly similar. I tweak the dimensions from an MK arcade so that explains the similar looks. Very cool I hope mine turns out as good as yours.  :cheers:
how tall, wide, and deep is the cab? and what size montior is that?
Mine so far is 24"high, about 16.5"wide, and 20" deep hoping a 17" monitor is going to fit very snug.
« Last Edit: January 23, 2010, 09:09:04 am by bigpete405 »
bigpete405
« Reply #58 on: February 07, 2010, 12:37:49 pm »
    Hey Pete, how do you have your plexi bezel mounted to the cab?, I see the two holes drilled in the bottom of the bezel, but what is keeping it from moving around? :dizzy:, pictures would be appreciated if possible, thanks.  :cheers:
-pete
