Author Topic: Ms. Pacman video trouble (please read)  (Read 4859 times)
aPr0mpt
  • Last login:August 08, 2011, 01:04:06 am
« on: June 19, 2009, 03:29:19 pm »
Hi everyone,
I have gotten these weird screens on my ms pac. it was flashing all sorts of garbage (see picture) then said something very quickly about bad rom 1. However, its working now and the colors are all wrong and distorted. Now matter how much i fiddle with the picture knobs, i cant get the real color back. Does anyone know what I should do? Is it the bad rom? Should i just keep playing with the wrong colors? what do you guys think?
Ms. pacman is like a dark grey or blueish color and when the ghosts are being chased they are red. There is also an unhealthy haze everywhere.
Thanks.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Ms. Pacman video trouble (please read)
« Reply #1 on: June 19, 2009, 03:57:19 pm »
Has it been working properly in your possession ? Anything change recently ?
You may want to check the PacMan Troubleshooting By Picture page.
Monitor looks like it could use a good capping as well.
Working: Not Enough
Projects: Too Many
Progress: None
SirPeale
  • Green Mountain Man
« Reply #2 on: June 19, 2009, 04:25:58 pm »
Fiddling with the picture knobs won't bring your colors back to normal - you've got a board issue.
First, reseat all your socketed chips, see if that helps.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: June 19, 2009, 04:35:15 pm »
Yeah, the first image with the "garbage" is most likely a chip that needs re-seating.
(i.e. ROM)
The monitor itself should probably have a cap kit done if it hasn't been done recently if ever at all.
The horizontal sync looks a tad off maybe causing the droop on the one side.
(could also be a cap)
The SCREEN voltage on the flyback may be a hair high causing the washout/haze and the lines.
Can't quite tell if the convergence is off from those pics.
Can't see much BLUE anywhere either.
And most importantly...... what make / model monitor is it ?
aPr0mpt
« Reply #4 on: June 20, 2009, 02:17:18 am »
Wow thanks for the help guys. I will definitely reseat the chips and will look up the monitor model when i get a chance.
aPr0mpt
« Reply #5 on: June 21, 2009, 12:55:44 am »
Ok, my model make and number on the monitor is an electrome M015-00092-0000. Which i believe makes this original.
aPr0mpt
Re: Ms. Pacman UPDATE
« Reply #6 on: June 23, 2009, 01:22:10 am »
After reseating the socketed chips there was a great deal of improvement! Colors are much better however some colors are still not correct. I didnt take the chips completely out, just a bit, would love to hear any suggestions.
I appreciate all of your suggestions.
Level42
« Reply #7 on: June 24, 2009, 04:33:48 pm »
That monitor really needs a cap-kit. It also looks like the green bias is up too high.
RobinHolland
  • Last login:March 13, 2013, 04:07:23 pm
« Reply #8 on: June 25, 2009, 02:53:41 pm »
There is no blue , only green and red
Kevin Mullins
    • Me on Myspace
« Reply #9 on: June 25, 2009, 05:08:49 pm »
So maybe a Electrohome G07 then ?
That monitor does seriously need a tech to go over it.
At least the basic chassis overhaul.
aPr0mpt
« Reply #10 on: June 27, 2009, 03:18:46 am »
So does everyone think its the monitor then? Is it worth getting a guy over from 30 miles away charging $75 an hour to take a look?
Level42
« Reply #11 on: June 27, 2009, 05:22:03 am »
I'd do a cap-kit myself first. It's really not that difficult to do.
But the missing blue could be anything from a loose pin to a dead blue gun...
If he's going to charge two hours (which I expect would be minimally required) it's the same price as a brand new monitor.
If you don't feel you have the capability to fix the monitor I'd sell it to someone who can and buy a brand new monitor.
« Last Edit: June 27, 2009, 05:36:40 am by Level42 »
aPr0mpt
« Reply #12 on: June 27, 2009, 03:21:02 pm »
Thanks Level 42,
Selling it would never be an option though.  :D I just wanted to know whats wrong with it so that i could either get the board fixed or try to get a new monitor.
« Last Edit: June 27, 2009, 03:27:02 pm by aPr0mpt »
Kevin Mullins
    • Me on Myspace
« Reply #13 on: June 27, 2009, 04:57:10 pm »
I would definitely have the monitor looked at first.
You can't properly troubleshoot a game with monitor symptoms like that without knowing it's NOT the monitor.
I personally can't stand techs that charge such prices.
30 miles is an every day one way drive for me, so I don't think twice about that part.
$75 an hour ...... rediculous.
 :soapbox:
Hell, ship the chassis to me and I'll do it and make it so your total cost is HALF of that including shipping.
aPr0mpt
« Reply #14 on: June 30, 2009, 02:15:23 am »
So listen to this, after talking to the tech. his solution is for him to take the monitor and board, take the monitor to new england coin op to get it tested and if needed repaired... and if its the board (it gets better) he says he can ship it out to get it repaired or i could chose to trade it in on this "website he knows". hahah lmao. what does he actually do???? well, whatever he does he wants $100 for the first hour but admits he wouldnt fix the board or the monitor... does he only deal with power supplies?? this is hilarious.
SirPeale
« Reply #15 on: June 30, 2009, 05:32:36 am »
You didn't mention you were in New England before.   Whereabouts?  I'm in Brattleboro.
aPr0mpt
« Reply #16 on: June 30, 2009, 12:36:52 pm »
oh yeah, I'm in Waltham, MA. right off of 95. Know any members by me that could help out?
SirPeale
« Reply #17 on: June 30, 2009, 01:41:36 pm »
If you want you can ship the chassis to me and I'll rebuild it for you.  PM me.
RobinHolland
« Reply #18 on: June 30, 2009, 03:10:02 pm »
Clean your edge connector on your galaxian pcb and your connectors on your monitor if this not work
Switch the red and bleu wire on your edge connector and you now if it is the board or the monitor
« Last Edit: July 01, 2009, 10:39:41 am by RobinHolland »
Level42
« Reply #19 on: June 30, 2009, 06:20:06 pm »
Holy smokes Peale, you're practically neighbors with my uncle & aunt who live in Drury !
Next time I visit them we should meet ! ! ! Your place is near Greenfield, we drove through there a lot of times ! :)
SirPeale
« Reply #20 on: June 30, 2009, 06:51:32 pm »
Sure thing!  Where's Drury?  Never heard of it.
I'm about 1/2 an hour from Greenfield.
Level42
« Reply #21 on: July 01, 2009, 04:50:58 pm »
Near North-Adams.  It's less than an hour:
We actually drove past your town on the 91 when we were heading for Funspot  ! :D
We may visit again next year ! :D
Sorry to de-rail this thread, back on topic.
« Last Edit: July 01, 2009, 04:53:38 pm by Level42 »
aPr0mpt
« Reply #22 on: July 01, 2009, 09:11:32 pm »
Do you know what the best thing is to use to clean the edge connector?
aPr0mpt
« Reply #23 on: July 09, 2009, 07:18:52 pm »
tried the pencil eraser and it made it look clean but no improvement.
Pencil eraser or lightly hit it with sand paper.
SirPeale
« Reply #24 on: July 09, 2009, 07:23:04 pm »
No, it wouldn't.  I'm still pretty sure you have a PCB issue.  Color PROM maybe.
channelmaniac
  • Last login:May 11, 2019, 12:36:18 am
    • Arcadecomponents.com
« Reply #25 on: July 21, 2009, 02:29:41 pm »
Well...
Why not swap the green and blue color wires on the inputs of the monitor? If you get blue and no green then the board is bad... if you still have green and no blue then you have a monitor issue.
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs are kept at: http://newlifegames.net/nlg/index.php?board=19.0
