Author Topic: FS: Pentranic 25" monitor and WG K4900 19" monitor [US/NC/Apex]  (Read 960 times)
shess
  • Last login:January 07, 2021, 04:17:28 pm
I've got a pair of working monitors for sale.  The Pentranic is model 1425 and is CGA/EGA capable.  It has a universal mount so it can be horizontally or vertically mounted using the same mounting holes.  It has the remote adjustment board and the tube is burn free.  The dimensions are nearly the same as the 25" WG K7000 monitor, give or take a half inch here and there.  See the link for pictures of it in action.  I don't know if this monitor can be run without the isolation transformer, I couldn't find a manual to check.  Because of the size, pickup is highly desirable.
Asking $175
The other monitor is a WG K4900 19" std res only monitor.  As seen in the pictures, the frame is different from the standard 19" frame in that it has the rear metal arms to protect the neck.  The mounting brackets for vertical and horizontal don't have the same hole spacing so it's not quite a universal mount, but still better than the standard horizontal mount frame.  This tube also has zero burn in.
Asking $50
Pictures:  http://www.flickr.com/photos/7205976@N06/sets/72157619941827014/
