Author Topic: standard chassis  (Read 1429 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
standard chassis
« on: June 16, 2009, 10:54:31 am »
can someone tell me whats the best standard resolution chassis out there
Kevin Mullins
    • Me on Myspace
Re: standard chassis
« Reply #1 on: June 16, 2009, 02:42:54 pm »
Kinda a vague question since you didn't post a tube size, nor whether you would have a matching yoke, etc.
alienware32
« Reply #2 on: June 16, 2009, 04:48:40 pm »
sorry about that its a 25 inch orion tube what i want to know is which chassis  out there has the better  picture quality in 15hz
Kevin Mullins
    • Me on Myspace
« Reply #3 on: June 16, 2009, 04:59:34 pm »
Well, they will all be about the same.  ;)
For a 25" I have to recommend a K7000.
Just reliable, easy to repair, etc.
BUT ..... you have to have a yoke that is compatible regardless of what chassis you use.
And the neckboard pinout needs to match as well.
Your other option would be to go with an aftermarket version that they can match to what you already have. (tube/yoke)
alienware32
« Reply #4 on: June 16, 2009, 05:06:02 pm »
that's what I'm talking about what aftermarket chassis you would recommend
