Author Topic: WebMAME now has HyperSpin support!  (Read 6981 times)
Lilwolf
« on: June 12, 2009, 06:37:37 am »
Ok, this was the initial idea for WebMAME (then got postponed for various reasons)... but its now working!
WebMAME can now control the game lists for HyperSpin!  The categories can now be tied to a genre in HyperSpin.  When you modify your category lists, it will then automatically create the genre.xml files in the database.
Have a game without a theme, but you have a theme that matches it?  (think SF2 but you have a great SFA theme?)  Well, you can now select it in the game page.  A list of all the themes will be available.
Want to set a default theme, go for it.
Want the description tags to be a bit easier to read... done.
Also added this release
24/7 game support...  Run a game... and let it just sit there... Ok, now from any other computer in the WORLD (assuming you have static ips, don't have a router, ect) can now specify what game you want to play!  Run your frontend on your home PC... Or just use the webpages to swap games.  Use for this?  Not sure, but I am hoping to write some IPhone safe webpages for a simple frontend.  Just would be cool to control my arcade from my phone :)
Added autosave also.  Now I'm starting to control enough txt files, I don't want to write them every time I add a game to a category or switch a theme.  So now you can make changes, and just hit save.
http://webmame.wikidot.com/start
