Author Topic: 3/4 vs 5/8  (Read 1152 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
3/4 vs 5/8
« on: July 06, 2003, 03:13:08 pm »
I'm using  Scott's Unicade support frame as an example for my cabinet. I live in L.A. and in an apartment. So
A. I know I will have to move and want the thing sturdy.
and
B. We have Earthquakes and I want the thing sturdy.
With that being said should I go with 5/8 pr 3/4 mdf. I personally think the 5/8 will be fine, since I have a support structure. I am worried about the coin door and my cp. I was thinking I should make the cp out of 3/4 and hope that 5/8 is enough to support the coin door on the front. Any suggestions? Is the support frame over kill?
Thanks in advance,
Shieldwolf
« Last Edit: July 06, 2003, 03:16:20 pm by shieldwolf »
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:3/4 vs 5/8
« Reply #1 on: July 06, 2003, 04:20:37 pm »
The only gotcha I can think of is that it might be more of a pain in the arse to find t-molding (and the proper slot cutter) for 5/8 than it would for 3/4.
For my next CP, I plan on using 5/8 with 1/8 plexi to give it a total depth of 3/4.
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
Re:3/4 vs 5/8
« Reply #2 on: July 06, 2003, 05:52:05 pm »
I used 5/8 on my whole cabinet and believe me, it's plenty strong even without that support structure.
You definetly don't have to worry about the coin door or control panel. I tried to actually rip out the coin door and I'm a big guy. Didn't even bend.
I get my t-molding from http://www.stievenart.com/ Really fast shipping and they have 5/8.
paigeoliver
  • Awesome face!
Re:3/4 vs 5/8
« Reply #3 on: July 06, 2003, 08:31:04 pm »
Also, you might want to work with plywood instead. Plywood cabinets last a lot longer and are much harder to damage.
night
  • Last login:January 09, 2018, 02:08:19 pm
Re:3/4 vs 5/8
« Reply #4 on: July 06, 2003, 09:34:04 pm »
i dont know anything about that frame, but they are solid as hell. 3/4 is serious overkill.
i am also in an apartment and i designed my cab based on lightweight for moving and easy to get apart. by i can promise you, it isnt going anywhere.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
Re:3/4 vs 5/8
« Reply #5 on: July 06, 2003, 11:57:59 pm »
I have a cab I built 15 years ago out of 1/2" MDO (plywood with a smooth veneer applied to both sides) and 2"x2"s and it has held up through 5 moves to 4 different states.  It is still just as solid as the day I finished it.  :)
Next I'll be on fries, and that's when the big money starts rolling in.
