Author Topic: Error "Ultrastick #3 should be plugged in , but cannot be found" ??!!  (Read 2142 times)
ARTIFACT
The title says it all
I have TWO U360 joysticks... Worked perfectly, then I switched PCs in my cab (check my sig for project!! :) )
and now this...
I tried "scanning" from the UltraMap program
It DID have a 3rd listed as plugged AT FIRST
When I ran the scan, it correctly marked #1 and #2 as plugged, only
Would MALA be "stuck" with the previous setting, and not be aware of the latest "scan" from Ultrastick?
This error appears ALL THE TIME ... starting mala, start game, end game, end mala (ggghh)
THANK YOU FOR YOUR HELP!!!
fatfingers
  • Got UltraStiks?™
This is not MaLa complaining.  It is the ultrastick mapper plugin.  Even more correct, it is UltraMap, which the plugin calls.  Fix the error with UltraMap, and this error will go away.
Good luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ARTIFACT
Oh I forgot to post the result
I somehow got it to work :)
It WAS something in the UltraMap software... it wasn't an obvious thing. Cant remember how I fixed it :)
fatfingers
  • Got UltraStiks?™
Was it the 'require this joystick to be connected' or similar checkbox that you then unchecked?   :)
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
