Author Topic: :FIXED: I get an error when booting a PC game.  (Read 4965 times)
bartre
  • Last login:March 19, 2018, 08:56:46 pm
  • I'm hesitating... again.
« on: June 04, 2009, 07:47:44 pm »
well, I've looked around on the forums and google, but i just can't figure out what i need to do.
I've got my Mala set up to boot PC games, but when i try to load Guilty Gear XX Reload it gives me an error
"Failed to execute program "". Error code 2."
now, i don't know what to do, because any other PC program that i try to load will simply run, i only get the error with Guilty gear
any help?
« Last Edit: June 04, 2009, 08:51:15 pm by bartre »
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: I get an error when booting a PC game.
« Reply #1 on: June 04, 2009, 08:05:16 pm »
it will usually fail to load with that error if the path to your shortcut is wrong.
check your path to your shortcut
check your shortcut actually works
bartre
« Reply #2 on: June 04, 2009, 08:16:03 pm »
okay, I checked both of those, and both passed, but i put a new shortcut in the folder just in case, but now all that happens is that it opens a command prompt, then closes and goes back to mala.
dungbeetle46
« Reply #3 on: June 04, 2009, 08:24:16 pm »
do you have %rom% under your command line
dungbeetle46
« Reply #4 on: June 04, 2009, 08:35:45 pm »
you may need to run it from a batch file
open a new txt file
in it put
@echo off
set path=c:\Program Files\put  your game here etc
start/max your game.exe
now save it as
whatever your game name is Guilty Gear etc.bat
now make a shortcut to this and launch from this shortcut
see if that helps
bartre
« Reply #5 on: June 04, 2009, 08:36:42 pm »
yeah, i do, and here's a couple pics of my config:
:EDIT:
i made the batch file, but now it just went back to error code 2
but the difference is that now it's reading out the file location of the original .exe
« Last Edit: June 04, 2009, 08:44:08 pm by bartre »
bartre
« Reply #6 on: June 04, 2009, 08:50:53 pm »
FIXED!
I used the batch file as suggested, but i had to mess with the file paths
After renaming some things, it worked perfectly!
