Author Topic: Mame Compile process fails  (Read 1586 times)
John_Virgo
  • Last login:June 09, 2009, 07:23:39 am
« on: May 29, 2009, 11:24:04 am »
I'm trying to compile MAME plus and it goes okay until I receive the following error message
Compiling src/osd/windows/scale.c...
Assembling src/osd/windows/scale/superscale.asm...
process_begin: CreateProcess(NULL, nasmw -o obj/windows/mamep/osd/windows/scale/
superscale.obj -f coff -Wno-orphan-labels src/osd/windows/scale/superscale.asm,
...) failed.
make (e=2): The system cannot find the file specified.
mingw32-make: *** [obj/windows/mamep/osd/windows/scale/superscale.obj] Error 2
I checked in the folder and I have a superscale.asm file in there but there's nothing about a superscale.obj.
What can I do to get it to compile?
John_Virgo
Re: Mame Compile process fails
« Reply #1 on: May 30, 2009, 08:50:57 am »
Any ideas? I think it has something to do with the extra_utils for Mame Plus and the 'nasmw' found in extra/bin but I can't find out what it's for or how to correct the errors. I built the exact same MAME fine a month or so ago but now there is an error and I have no idea why.
« Last Edit: May 30, 2009, 09:06:32 am by John_Virgo »
John_Virgo
« Reply #2 on: June 09, 2009, 07:23:57 am »
anyone?...  :o
abispac
  • Last login:December 04, 2025, 01:12:34 am
« Reply #3 on: June 09, 2009, 09:39:48 am »
someties when that happens to me, i try making everything from start, erase everything, download all again and start, are you building mame32? if so i found mr.do page instructions on mameworld.info very usefull,  :cheers:
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: June 09, 2009, 07:15:43 pm »
The obj file will be in the obj folder (from the mame folder).  See if it exists, and if it's blank or not.
What I'd do is delete the superscale object files from the obj folder, and try compiling again.  If that does fix it, I'd delete the same object files and the asm file you found (since it was created in the compiling).  If that's not good enough, try "make clean" and then compiling again.  If that doesn't fix it, I'd do as abispac said and start over.
Robin
Knowledge is Power
