Author Topic: trackball grounding.  (Read 1609 times)
masterosok
  • Last login:September 12, 2009, 09:51:18 pm
« on: May 28, 2009, 05:31:44 pm »
I have a PSU mounted in my control panel to power my LEDS and trackball. I am curious what the best option for me would be to ground my trackball since my computer case will not be anywhere near my control panel.  Would grouding it to a screw on the back of the PSU be safe?
BobA
  • What Me Worry?
Re: trackball grounding.
« Reply #1 on: May 29, 2009, 08:57:12 am »
The PSU should be grounded via its 3 prong plug.   If this is intact then grounding to the case of the PSU is a safe bet.
masterosok
« Reply #2 on: May 30, 2009, 05:28:03 pm »
Vicious Burger
  • Last login:June 25, 2021, 01:34:03 am
  • The gristle ball that gives at good as it gets
« Reply #3 on: June 13, 2009, 12:59:42 pm »
I have a similar question,
I have a Happ trackball in my CP connected to the Opti-Wiz with an adapter cable from GGG. There are a pair of green wires that come off the trackball and join together at a connector,which I assume is a ground wire,(isn't ground usually black?) but where should i ground it? The PC is inside the cabinet,should i run a wire to the PC case to ground it? All my other controls (joys & buttons) work fine,they have all the ground wires on them,and are all connected through the Ipac4. Spinner is USB.
I checked with my multimeter that power is coming from the optiwiz,and it is getting 5v through the adapter cable.
« Last Edit: June 13, 2009, 02:51:53 pm by Vicious Burger »
