Author Topic: CPViewer Problem -- Run time error 5  (Read 2418 times)
Hoagie_one
  • Um....whats a cabinet
« on: May 24, 2009, 11:24:17 am »
I'm setting up cpviewer for the first time and it needs to generate 3 .ini files from the mame xml file.  When I run the setup utility to create these ini files, it generates one of them then crashes with a run-time error 5.
Any idea whats causing this?
Mike
headkaze
  • 0x2b|~0x2b?
Re: CPViewer Problem -- Run time error 5
« Reply #1 on: May 24, 2009, 06:48:18 pm »
Can you please post your CPWizard.ini and CPWizard.log file after this error occurs.
Hoagie_one
« Reply #2 on: May 25, 2009, 10:06:05 am »
I dont have any cpwizard files.  I'm having issues with cpviewer (CPVS).
« Last Edit: May 25, 2009, 11:00:57 am by Hoagie_one »
Hoagie_one
« Reply #3 on: May 29, 2009, 11:53:25 pm »
anyone else have any ideas?
Hoagie_one
« Reply #4 on: June 02, 2009, 09:12:46 pm »
tried it on two computers with the same result.  i shed tears of sorrow.
guess ill just have to try and get cp wizzard working instead
welshmark
  • Last login:February 08, 2010, 02:21:16 pm
« Reply #5 on: January 09, 2010, 04:19:59 pm »
I get the same error on CPViewer when trying to create the 3 ini files from the mame.xml file.  I backtracked through MAME versions and found that the last version this worked correctly on was 129, so I generated my ini files from that.  Anyone found a way around this for versions 130+?
