Author Topic: U5000 Blooming issue  (Read 1215 times)
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« on: May 24, 2009, 09:47:44 am »
I have a U5000 that has an interesting problem.  It's geometry changes based on the input signal.  So a brighter picture will squish both top and bottom of the raster
It has had a new cap kit, swapped flybacks and the other standard U5000 checks.
Any idea?  I do I do thru each cap again?  I know they are all in the right direction
Thanks,
s
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: U5000 Blooming issue
« Reply #1 on: May 24, 2009, 01:04:02 pm »
blooming is an effect of a weak crt .
it may be minimized by reducing drive ( pending gun condition) .
if resulting pic is too dark, rejuvination or crt replacement will be required ...
qrz
castlesteve
  • uh, yea
« Reply #2 on: May 31, 2009, 08:53:16 am »
it happens on multiple tubes.  ill try replacing the la7850 next
qrz
« Reply #3 on: May 31, 2009, 10:48:00 pm »
i re-read ur original post ( i hadn't got past blooming - sorry !!  )
the vert output ic is on it's way out .
replace it and double check the bootstrap diode /cap
cathode should be higher v than anode when circuit functioning properly
qrz
