Author Topic: Happs Trackball Question!  (Read 875 times)
BobtheAddict
  • Last login:October 29, 2010, 12:00:22 am
  • Icy Cold Beverages
« on: May 23, 2009, 04:35:16 pm »
This weekend I was testing out my control panel and it seems I mounted the trackball in the wrong direction. Instead of mounting the roller ball with the arrow facing in the up position, it is pointing to the left.
I already have it mounted and sealed up with bondo and there is no way I can spin it around to the right direction. Do you know if there is a way in Mame or Windows XP that I can change the direction on the roller ball.
If not, I am screwed!  :banghead: Any help is greatly appreciated.
Here is a picture of the trackball in case you need a visual.
« Last Edit: May 23, 2009, 04:46:07 pm by BobtheAddict »
BobTheAddict
Paul Olson
    • Paul's Arcade
Re: Happs Trackball Question!
« Reply #1 on: May 23, 2009, 04:45:42 pm »
Swap the plugs on the optic boards, then you should be OK. If the axes are correct but the direction is reversed, you can reverse it in MAME.
BobtheAddict
« Reply #2 on: May 23, 2009, 04:47:54 pm »
Does it make a difference if it is USB?
http://www.happcontrols.com/trackballs/560100e.htm
BobTheAddict
