Author Topic: Which MAME version dropped the high-score saving hack for classics?  (Read 2604 times)
Blanka
The title almost says it all. Up till version X, MAME had a built in hack to save highscores for the classics from the 70-ies and 80-ies, which lost their high-scores after turning the machine off and on. Today with the more accurate emulation of MAME, the highscores are wiped, as running a MAME emulation is similar to booting a machine. So which version still had the hack for high-score saving?
R0UNDEYEZ
  • Last login:March 16, 2015, 03:39:15 am
Rather than go back to an older version of mame that supports less games..follow the directions here:  http://forum.arcadecontrols.com/index.php?topic=64298.0
its real easy to do,i've done it twice now with no issues.
*edit* and if it was a question just out of curiosity and not that you needed high score support it was version 107 that was the last one that supported it
« Last Edit: May 19, 2009, 05:37:35 am by R0UNDEYEZ »
Blanka
That trick probably does not work for MameOSX  :D
What version does it work on? And aren't there any pre-compiled ones?
Hoopz
  • Intellivision Rocks!
.106 was the last version with the hack enabled.  One of the "u" releases after .106, but before .107, implemented the new system.
Ummon
  • Trade Count: (+13)
Ask around the mac forums.
No. Or at least not obviously known, though I guess you could compile your own, it really ain't hard given the work of headkaze, and then, hey, you could host and promote a compiled version. Or, hey, even more so, you could support a 'currently-compiled' version. A small cause, but perhaps worthy.
Yo. Chocolate.
Stephen Hawking
Hoagie_one
  • Um....whats a cabinet
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
maybe this will help
http://highscore.mameworld.info/
Also MAMEFX and MAMEXT have hiscore support.
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
Mameplus also has built in support for highscores.
