Author Topic: front end Shell and volume control? *solved*  (Read 1104 times)
Bender
« on: May 19, 2009, 01:02:09 am »
I'm using Maximus as my shell and I want to use the media keys from my computer to control the volume in the FE
problem is the buttons don't work unless windows explorer is running
is there a program I can set to launch when the Shell launches that will let the media control buttons work? besides explorer of course
Thanks for any help!
« Last Edit: May 22, 2009, 02:07:47 pm by Bender »
headkaze
  • 0x2b|~0x2b?
Re: front end Shell and volume control?
« Reply #1 on: May 19, 2009, 01:04:46 am »
Check out the Audio Tools section here
Bender
« Reply #2 on: May 19, 2009, 08:52:02 am »
thanks
I had already tried the first two and they don't work the media buttons
any other Ideas?
what runs the audio in explorer?
Bender
« Reply #3 on: May 22, 2009, 02:07:19 pm »
Thanks Headkaze
I was wrong... again :-[
CabVol does infact do the trick just had to uncheck the hot key button :cheers:
