Author Topic: roms not booting in mala  (Read 2754 times)
liquidsins
  • Last login:May 27, 2010, 03:44:25 pm
« on: May 18, 2009, 06:19:55 pm »
sorry if been covered before but im stuck, i have done lots of reading but cant find solution anywhere. the roms start fine when booted straight from mame but when im in mala and click button to start a game the starting message comes up but then just disapears  and nothing happens, can anyone shed any light on this please? im using mame 0.100 which i know is old but it runs well for me and i have had it working with mala before but now i just dont know whats happened thanx.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: roms not booting in mala
« Reply #1 on: May 18, 2009, 08:25:57 pm »
Are the paths to the executable, the xml file, and the roms correct? Is the command line correct? Have you tried right-clicking and choosing "Refresh Main Game List?  Does the xml file actually exist?  You may have to post a screen shot of Mala's mame configuration.
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #2 on: May 19, 2009, 03:53:17 am »
Getting started
• Download the Windows command line version of MAME
• Extract MAME in a directory on your harddisk (eg c:mame)
• Optional: Download catver.ini (Genre)
• Optional: Download controls.ini (Controls)
• Optional: Download history.dat
• Copy all optional files in the MAME directory
• Download MaLa from the download page
• Extract or install the program on your harddisk
• Execute MaLa
• The options dialog will open
• Point the MAME executable to your mame.exe file
• MaLa will create a mame.ini and a mame.xml file for you if not found
• Enter a rom path and a snap path
• Close the dialog and MaLa will ask you to refresh the main game list.
Accessing more options
Just click with your right mouse button somewhere on the background to open a popup menu.
liquidsins
« Reply #3 on: May 19, 2009, 11:26:51 am »
thanks alot guys dont know quite what it was but just erased what id done and started again, at 1 point i think i had about 4 xml files in there so think it prob to do with them. thanx anyways
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« Reply #4 on: May 20, 2009, 01:05:51 am »
Liquid,
I had trouble with this, too. Three things I learned: 1) Many roms online are bad, incomplete, etc. 2) It works best if you find roms from the rom set that match your version of Mame. You may need to upgrade to a newer version of Mame, because it's hard to find older rom sets. 3) Some roms just don't work with Mame. I eventually got about 95 percent of the games I needed working great, so there's much trial and error. Good luck!
