Author Topic: Ctrlr INI Setup  (Read 1423 times)
Ctrlr INI Setup
« on: July 04, 2003, 06:56:59 am »
Does anyone know how to refer to an analog sticks 'slider' (3rd Axis) in the ctrlr ini files?
The MAME UI refers to it as 'J1 Slider +/-', but I am unsure how to do this in the ini file.
This is in the ctrlr docs:
With respect to the windows port, the generated keycodes are identical to those displayed in the configuration menu with all spaces replaced by underscores.  For example, the keycodes automatically generated for a Wingman Warrior joystick are:
J1_X-axis_+        J1_X-axis_-        J1_Y-axis_+        J1_Y-axis_-
J1_Z-axis_+        J1_Z-axis_-        J1_Rz-axis_+       J1_Rz-axis_-
J1_Button_0        J1_Button_1        J1_Button_2        J1_Button_3
J1_POV_0_U         J1_POV_0_D         J1_POV_0_L         J1_POV_0_R
The names generated will vary with the port to which the joystick is connected.  In the codes listed above, the Wingman Warrior was connected as the first joystick (J1).  If it had been configured as a different input, the generated codes would have a different Jx number.
All keyword matching including the standard keywords is case sensitive.  Also, some of the automatically generated OSD codes may be redundant.  For example, J1_Button_0 is the same as JOYCODE_1_BUTTON1.  Standard codes are preferred over OSD codes.
...so with that in mind, I suppose 'J1_Slider_+' and 'J1_Slider_-' should work, but it does say 'Standard codes are preferred over OSD codes', what are the standard codes in this case?
Thanks for any help
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Ctrlr INI Setup
« Reply #1 on: July 04, 2003, 08:33:33 am »
Thanks for any help
There is no standard code for a third axis.  You will need to use the 'J1_Slider_+' and 'J1_Slider_-' terms.  Much like if you want to use buttons greater than #6, you need to use the OSD codes. *shrug* :-\
(For programmers only) FWIW, your slider is probably the "7th" axis, as the directX directInput standard offset numbering is:
1: X axis
2: Y axis
3: Z axis
4: rX axis
5: rY axis
6: rZ axis
7: slider 1
8: slider 2
However, it is up to the driver to follow this standard or not.  Also the old dX standard it was okay for a slider to be axis with offset # 3 if there was no regular Z axis.  This is all hidden from the users, however, as even the current way, if there is on Z through rZ axes, the slider is seen as the third usable axis.  The programmers need to know this, but not the users.
Robin
Knowledge is Power
Re:Ctrlr INI Setup
« Reply #2 on: July 04, 2003, 10:31:03 am »
OK Thats great, thanks URebel :)
