Author Topic: Help with Arcade OS 2.5 control settings  (Read 1345 times)
unite2k
  • Last login:June 06, 2009, 05:45:31 am
« on: May 17, 2009, 06:57:25 am »
Morning guys,
After a flat move I finally found place for my "ARCADE TIMEWARP" Mame Cabinet. Its running ARCADE OS 2.5, after 5 years of storage... it still runs smoothly  :D
The problem I have is with the joystick configuration, somewhere along the way, someone messed up the settings. Right now I can't set-up the buttons properly. I've tried changing the "GENERAL INPUT" while running a game with little luck.  ???
Is it possible to completely reset the button/joystick configuration through Arcade OS 2.5? If not, is this possible by replacing the windows configuration file?
Thanks in advance,
Ced
SirPeale
  • Green Mountain Man
Re: Help with Arcade OS 2.5 control settings
« Reply #1 on: May 17, 2009, 07:41:40 am »
IIRC all this info is stored in arcadeos.cfg.  Rename it to something like "arcadeos.bak" and run arcadeos.exe.  It'll generate a new one.  Then you can make your changes as necessary.
unite2k
« Reply #2 on: May 31, 2009, 06:27:32 am »
SirPeale, thanks so much for the response. My bad for not checking this board sooner.
I just tried it, and it changes the display settings (turned split screen, high res) and games no longer load once selected.... luckily I did as you advised and kept the original arcadeos.cfg :)
So I'm back to square one.... My bootdisks don't work so a complete restore won't be happening.
The only settings I want to change are the JOYSTICK config, as far as Im aware these are only modifiable once a game is loaded. Then you can change individual GAME CONFIG and ALL GAMES CONFIG, is there a way to reset just this??
If not, what other solution would you use?
Tks again, Cedric
SirPeale
« Reply #3 on: June 06, 2009, 08:27:36 am »
Tks again, Cedric
Once you delete that file you'll have to set the parameters back up in arcadeos.cfg.
Usually at the DOS prompt you type:
EDIT ARCADEOS.CFG
depending on what version of DOS you're running, of course.
