Author Topic: Nieman 24.8''CRT MAME Looks too flat / crispy , video settings help .INI Inside  (Read 2580 times)
mrclean
    • Guscade
I noticed that my MAME games look too crispy / "flat like"  on my new CRT 24.8'' .. What are the video settings I should be using ?
I've been away from my MAME cabinet for a while all of my other dedicated games are using CGA monitors and look alot better.
here is the link to my monitors specs : http://niemandisplays.com/nvd%203m%20spec%20electrical%20spec%20sheet.pdf
here are my MAME 129 settings:
<UNADORNED0>
# CORE CONFIGURATION OPTIONS
readconfig                1
# CORE SEARCH PATH OPTIONS
rompath                   roms
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE FILENAME OPTIONS
cheat_file                cheat.dat
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  1
playback
record
mngwrite
wavwrite
# CORE PERFORMANCE OPTIONS
autoframeskip             1
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
# CORE SCREEN OPTIONS
brightness                1.000000
contrast                  1.0
gamma                     1.000000
pause_brightness          0.650000
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.000000
flicker                   0.000000
# CORE SOUND OPTIONS
sound                     1
samplerate                44100
samples                   1
volume                    0
# CORE INPUT OPTIONS
ctrlr
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
# CORE MISC OPTIONS
bios                      default
cheat                     0
skip_gameinfo             1
# WINDOWS DEBUGGING OPTIONS
oslog                     0
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  2
effect
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    4:3
resolution                640x480
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              1
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             1
# INPUT DEVICE OPTIONS
dual_lightgun             0
« Last Edit: May 15, 2009, 12:17:53 am by mrclean »
2,370,650 Gun.Smoke
ahofle
    • Arcade Ambience Project
Have you tried running the games at CGA resolutions instead of 640x480?
isucamper
    • my project arcade blog
Of course that'll look better, but he's either got a Nieman that can't do CGA, or a Nieman that won't digitally multisync and will be tough to configure for CGA and a higher resolution frontend.
I'm suprised you describe the picture as "crisp" since your using 'video d3d' and 'filter 1' which, in my experience produces a very soft, fuzzy picture at 640x480.
One thing to try.  Use 'video ddraw' and 'hwstretch 0'.  This will produce a very clean picture.  The one problem with this is you loose the correct aspect ratio for many games.
THE SYSTEM          Popeye
mrclean
    • Guscade
What do I put in my MAME settings to change that ?
I'll try anything it just looks like crap-o-la IMO i'm just used to my dedicated CGA monitors. I havn't tried anything else yet.
again here is my monitors specs: http://niemandisplays.com/nvd%203m%20spec%20electrical%20spec%20sheet.pdf
« Last Edit: May 15, 2009, 11:12:42 am by mrclean »
2,370,650 Gun.Smoke
isucamper
Ok, first of all, you've got the tri-res Nieman which is capable of th native CGA resolutions that most old arcade games use.  You could try SailorSat's Soft15Khz program (if you've got a compatible video card) and see if you can get CGA resolutions going.  Just know that because you're monitor does not have any digital memory, you can't bounce between CGA (arcade game resolutions) and VGA (your front end) without making adjustments to the monitor's pentometers (not something you want to be doing every time you play a game).
If you want to try and get a cleaner picture at 640x480, try these mame options.
Under WINDOWS VIDEO OPTIONS
video                     ddraw
under DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
Again, some games will lose their correct aspect ration, but others will be close and look a lot cleaner.
THE SYSTEM          Popeye
cmoses
Mr. Clean,
Could you post some pictures of what you are comparing?  I have a different display, WG D9200 running at 640 x 480 and think it looks really good.  Now I was using a 20" LCD so that maybe the reason.  I do not have access to any CGA monitors to compare apples to apples.
I run my games with D3D, not positive on the filter setting, but I have not changed it so it would be whatever the default is.
mrclean
    • Guscade
I installed the soft 15k program, and I don't know how to force my graphics card to that setting ? it seems to be at 60hz at 640x480 I'm using ATI Catylist software if that helps
2,370,650 Gun.Smoke
isucamper
did the CGA resolutions get installed?  if your not sure, run quickres and see which resolutions are selectable.
http://www.dougknox.com/xp/utils/xp_quickres.htm
THE SYSTEM          Popeye
Ummon
  • Trade Count: (+13)
mrclean, you need to read how mame works with native res. Also, use mame32 to set things - that is, use the graphical interface. Or, edit the values in your ini, but some things you obviously won't just know whether they're '0' or '1' or an ascending value, etc. Anyways, first, try out D3D with prescale at '1'. (with mame after the video-rewrite) Only use ddraw for native resolutions.
« Last Edit: May 19, 2009, 04:49:39 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
