Author Topic: Will this work? MAME System Link...  (Read 4357 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: May 10, 2009, 06:33:10 am »
I have one of these...
and am awaiting one of these...
...having seen 2 lovely Net Cities system linked so that player one uses 1 cab and player 2 uses a second to play against each other, I just wondered whether there was a simple way to do this in MAME between these 2 machines.
I have no motivation to modify either of these 2 cabs so I am intending to get a JVS-Pac for the Naomi and I already have a J-Pac for the Egret II. If I was to purchase a KVM box which had the possibility of splitting the image across 2 screens could I set up the 2 cabs using one PC, so that Player 1 takes one cab and Player 2 takes the other? I have a feeling this would work as, as far as I'm aware, the JVS-Pac uses USB and the J-Pac uses PS/2 so there should be no conflict.
Let me have your thoughts guys! :cheers:
dreamakuma
  • Last login:July 08, 2010, 02:14:54 am
Re: Will this work? MAME System Link...
« Reply #1 on: May 10, 2009, 10:46:37 am »
I've done it before. should work if all you are doing is splitting a video image and not try to do some weird system linking.
Newbie in working on cabs, expert in playing, breaking, moving slowly, and overall failing at them too.
slapaham
« Reply #2 on: May 10, 2009, 11:00:49 am »
I overcomplicated it a before in my describing. As the J-Pac uses PS/2 connection and the JVS-Pac uses USB then it's just a case of plugging both upto the PC and using a video splitter to each cab... should be simple enough.
Thanks :cheers:
  • Last login:Yesterday at 04:07:15 pm
« Reply #3 on: May 10, 2009, 11:05:04 am »
Thanks :cheers:
ha! I agree. I was over thinking it figuring it needed some sort of system link. Splitting the video is the perfect easy solution.
slapaham
« Reply #4 on: May 10, 2009, 01:09:26 pm »
I guess you could probably even make the 2 cabs function as a 4 player set up? The J-Pac would allow you to reconfigure the keys to players 3 and 4 while the JVS-Pac would act as players 1 and 2...
Ginsu Victim
  • Comanche, OK -- USA
« Reply #5 on: May 10, 2009, 04:38:05 pm »
Yep, you sure could.
slapaham
« Reply #6 on: May 10, 2009, 05:43:37 pm »
Cheers everyone for this! All sounds very promising/interesting. JVS-Pac has now been ordered just have to find the time to get everything in place!
