Author Topic: Fan Hole Size dilemma 80mm  (Read 2325 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: May 08, 2009, 07:44:03 am »
I have two 80mm(3inch) fans in a juke that i need to cut a hole for.  I think the full 3 inch hole that these preferably require would make the 4inch box I made to house the juke too flimsy, so what if I put in a 2.5 inch hole instead?  Would that damage the fans in the long run by choking the air and making them work harder, or is it not that big of a deal?  Also I feel that the 80mm fans are plenty for this setup so if the air flow is a little less the juke will survive.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Fan Hole Size dilemma 80mm
« Reply #1 on: May 08, 2009, 08:20:52 am »
Shouldn't make a bit of difference. As long as it is able to pull in/push out some fresh air you will be fine. I wouldn't worry about sructural integrity though if you are concerned about that. Most ply or MDF boards over 1/2" thickness are surprisingly tough, especially when all screwed together in a 'box'.
Chunce DeLeone
« Reply #2 on: May 08, 2009, 11:08:27 am »
Thanks Turncades!!!!  Now I am leaning towards the 2.5 inch hole, the reason i am worried about structural integrity is that it is close to the corners, so the screwed in part is probably going to take a hit with the hole
Franco B
« Reply #3 on: May 08, 2009, 11:37:18 am »
You don't have to use the mounting holes if you are afraid that they will be close to the edge. There are a few ways you could secure them but I would probably make a couple of 40mm or so long clamp blocks out of MDF and then use them to centrally clamp the fan to the inside of the box.
Something like:
Side View
Top View
Turnarcades
    • Turnarcades
« Reply #4 on: May 08, 2009, 12:03:44 pm »
Yeah... what franco said....  :)
