Author Topic: Is my folder structure right? (screenshot inside)  (Read 2150 times)
Mickelonis
  • Last login:November 24, 2017, 06:23:25 pm
« on: May 04, 2009, 10:11:05 pm »
Ok,
So I decided I wanted hi score abilities.... I read that it's not too hard to compile your own version, so I did just that.... Followed documentation, etc...
I ended up with a mame.exe that was 30mb in size... (big)
My mame directory now looks like this:
That seems kinda small to all the folders I saw before compiling.... Do all I really need is what's listed above?
PS. I'm using maximus arcade as a frontend...
-Pete
Robbbert
  • Last login:Yesterday at 12:22:59 am
Re: Is my folder structure right? (screenshot inside)
« Reply #1 on: May 05, 2009, 06:04:20 am »
I don't know what "movies" is about..
you probably could do with a "cfg" folder and a "ini" folder.
If you're playing games that need sound samples you need a "samples" folder
The rest (snap, folders, cabinet, flyers etc) is up to you.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: May 05, 2009, 05:32:58 pm »
Mame will create most of the folders it needs to run & save its info.  You just need to add the folders that you supply the data: roms, samples, artwork, etc.
Robin
Knowledge is Power
