Author Topic: Type of paint to use?  (Read 4066 times)
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
« on: April 30, 2009, 09:27:16 am »
Is there any paint I should avoid using on MDF?
I saw one cabinet I liked that had glidden satin vinyl black paint on it.  Will that be ok on MDF?
Just trying to make sure it is ok, since I have read how MDF is sensative to certain substances (namely water).  Also, I am putting a mamemarquees CPO on my control panel.  It says to paint with latex/oil paint containing no waxes or silicones.  How can I tell if the paint meets that requirement?
Also, any recommendations on what paint/primer to buy would be great.
-Nick
« Last Edit: April 30, 2009, 10:57:24 am by nickynooch »
Re: Type of paint to use?
« Reply #1 on: April 30, 2009, 09:35:18 am »
Pretty much any normal paint will work so long as you prime it properly.
Haterot
  • Last login:November 09, 2012, 09:27:41 am
« Reply #2 on: April 30, 2009, 12:38:03 pm »
go low/no VOC
Save the world, save yourself!  ;D
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
nickynooch
« Reply #3 on: April 30, 2009, 03:20:02 pm »
Sweet I'll look for some no/low VOC stuff.
« Last Edit: April 30, 2009, 03:22:19 pm by nickynooch »
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #4 on: May 02, 2009, 07:59:00 am »
I'm real happy with the paint that I chose:
http://forum.arcadecontrols.com/index.php?topic=82241.msg877560#msg877560
(although I bought way too much for one cabinet)
Here are a bunch of photos that show off the results (and my cab  ;D )
http://forum.arcadecontrols.com/index.php?topic=82241.msg870125#msg870125
... Why is it that you always find it in the last place that you look? ...
nickynooch
« Reply #5 on: May 03, 2009, 01:16:45 am »
Great links and props on the cab.  The paint looks great!
pmowry
  • Last login:September 06, 2016, 11:57:00 am
« Reply #6 on: May 05, 2009, 04:27:28 pm »
Paulscade, your cabinet looks great!! mine is based off the same plans.
But I noticed from your picture that you used a water based primer.  I used Kilz oil based since it is going on MDF.  Then I had a hell of a time locating black satin oil based paint for the bottom half and inside.  Still choosing the color for the top's outside.
but anyway, did I just cause to much trouble for myself going with oil based since it looks like I did not have to?
TOK
  • The Game Always Wins
« Reply #7 on: May 07, 2009, 09:36:32 am »
Rustoleum in cans is oil based and they make a satin black. If you're looking for a finish that is authentic to what the games actually used, oil is the way to go. You made a great choice!
« Reply #8 on: May 07, 2009, 09:42:11 am »
I think that depends on what state you're in... some states have really cracked down on oil based paints.  You can't even get large containers of enamels in MA anymore without looking really hard.
TOK
« Reply #9 on: May 07, 2009, 09:56:12 am »
I'm in PA, and this is one of the states that has rules in effect. What you say is correct, in that I didn't see oil based paint in 5 or 1 gallon containers. No problem finding it in quart containers, 2 of which are perfect for the average sized cab.
pmowry
« Reply #10 on: May 15, 2009, 12:16:35 pm »
I live in a very small louisiana town.  Finish and color selection in oil is very limited at the hardware stores near by.  The true paint stores a little north of me have a better selection of finish and can mix whatever color, but only in gallon size.  So  the extra paint will just give me an excuse to build another one  ;D
After all it would be a shame to let it go to waste.
