Author Topic: Fe problems....or vid card  (Read 1975 times)
Firebat138
  • Last login:October 29, 2025, 09:53:02 am
  • Head Brewer and Arcade Enthusiast
« on: April 29, 2009, 10:06:47 am »
i installed on OLD ATI Rage 128 in an older computer...  MAME will not run full screen...I have tried everything...  At work on my work computer is where I am testing and I have a Nvidia 4500 and it works fine from my external HD...  I am also using a tril of Maximus so far....Does this card have any issues that anyone knows of...It was free...so no worries here...I just dont want to buy another card and have it not work also...Thanx
Camper
Click below to see my Metal Gear/Splinter Cell Machine... http://forum.arcadecontrols.com/index.php?topic=108360.0
Click below to see my PinCab - PinWARS
http://forum.arcadecontrols.com/index.php/topic,164660.0.html
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Fe problems....or vid card
« Reply #1 on: April 30, 2009, 07:21:20 am »
What you mean by not working full screen?
Does it run windowed?   or  do you see black row on the left and right?
Or else?
Do you use a TFT (Flat) screen or a CRT (not flat) ?
Firebat138
« Reply #2 on: April 30, 2009, 09:03:32 am »
yeah.. windowed...  I am using an old crt screen, but i take the same programs and run it on another computer and it runs fine...It must be the rage card...
youki
    • Atomic Front End
« Reply #3 on: April 30, 2009, 09:09:18 am »
I don't thing. If it is windowed  (i mean you see the game in a window like it was normal windows application , with title bar ect..).  It should be just a mame settings.
Do you have a mame.ini file in your mame folder?
Or a setting in maximus .
When you are on the game, if you type the key : ALT+ENTER  (first ALT , keep pressed and press Enter)  What happens?
Firebat138
« Reply #4 on: April 30, 2009, 01:29:20 pm »
Hmmm...I will try that...I am at work now, but I will check it out...
Ummon
  • Trade Count: (+13)
« Reply #5 on: April 30, 2009, 03:39:40 pm »
Use mame32. See if 'stretch to fit' is grayed out. What OS are you using? Regardless, you might need drivers.
Yo. Chocolate.
Stephen Hawking
Firebat138
« Reply #6 on: May 01, 2009, 09:02:12 am »
is there a difference in mame32 and mameui32...
And I dont see that option...  I have start out maximized and thats it...
« Last Edit: May 01, 2009, 09:04:07 am by Firebat138 »
Ummon
« Reply #7 on: May 02, 2009, 03:11:40 pm »
Yes - look up 'mame video re-write'. Then, depending on which 'era' you're using, read the help file of it.
Yo. Chocolate.
Stephen Hawking
Firebat138
« Reply #8 on: May 02, 2009, 03:36:11 pm »
ok...where do i download just mame32?  thanx
Firebat138
« Reply #9 on: May 03, 2009, 03:59:10 pm »
ok...i havean old version of mame32...  .90 I think...  it works great on the one computer and mameui32 will NOT go full screen.  I am using a BUNCH of vid cards and none of them will take ui32 to full screen.  So am I stuck with using mame32...are there any disadvantages to this at all...  THis old  computer is a duron 1.66 with 2GB Ram...should be fine....  Thanx for your help
Camper
Ummon
« Reply #10 on: May 04, 2009, 05:46:33 pm »
What OS? What video card drivers? What are your mame video settings?  What kind of monitor are you using?   In answering these questions, you'll have to figure out how these things work, and work together/are dependent upon each other.
Yo. Chocolate.
Stephen Hawking
Firebat138
« Reply #11 on: May 04, 2009, 06:59:51 pm »
Win Xp Sp3, Most current drivers for the Rage 128, Mag 795 is the monitor, OLD crt, Mame is set to full screen...
The computer is an old AMD 1.66 Duron with 2gb Ram.  Weird...  Thanx for your help...OF course all this is pointless once I change my monitor...LOL...  Thanx
Camper
Firebat138
« Reply #12 on: May 05, 2009, 09:31:43 pm »
UPDATE:
OK...  I have tried everything...  Is it possible for the motherboard of the computer to be causing this.  I have everything loaded on a MYBOOK and tried it on several computers and this one is the only one that does this.  I even tried MameFX, which I like the interface, it does the same thng.  Here is something i noticed, when the program works the way I want, the monitor does that ON/OFF thing and goes full screen.  On the other computer, it just loads in a window...   Again...AMD, Athalon, 1.25, 2GB Ram..etc...  I can not seem to figure it out....
Thanx all
Camper
Ummon
« Reply #13 on: May 06, 2009, 04:38:22 pm »
I think you have 'switch resolutions to fit' enabled. If so, turn it off.
If that ain't it: with XP no drivers are needed for a rage128, so you could be having some conflicts. I couldn't ever find any that would load, then found out they were included in XP. What other cards did you try?
Yo. Chocolate.
Stephen Hawking
