Author Topic: Dreamcast woes  (Read 1626 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
Dreamcast woes
« on: July 02, 2003, 04:46:07 pm »
So my recently bought Dreamcast dies...or rather the controller ports do (i think) and a week after the return policy is up. The thing turns on but it doesnt register any VMUs or controllers. So about 30 min. ago I go buy a new one and it does the same thing. Is something up or am I having bad luck.
Derek
PS. I know this is off topic for these boards but  :'(
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:Dreamcast woes
« Reply #1 on: July 02, 2003, 06:11:56 pm »
sounds like a prob with you controllers. have you tried different controllers?
« Last Edit: July 02, 2003, 06:12:22 pm by jakejake28 »
It's all about the Pentiums
crashdmj
  • Hulk smash!
Re:Dreamcast woes
« Reply #2 on: July 02, 2003, 06:29:57 pm »
Yeah sadly I tries each of my 4 controllers.  :'(
SNAAAKE
  • -Banned-
Re:Dreamcast woes
« Reply #3 on: July 02, 2003, 07:43:51 pm »
Did you connect any controls while the system was on??
never EVER do that.
That blows out the ports..you might be able to fix it if you replace the blown fuse but I dont have any detailed info...
Dave_k might come in handy.
PM the guy about replacing the blown fuse ! :)
« Last Edit: July 02, 2003, 07:44:03 pm by SNAAAKE »
crashdmj
  • Hulk smash!
Re:Dreamcast woes
« Reply #4 on: July 02, 2003, 10:50:59 pm »
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
Re:Dreamcast woes
« Reply #5 on: July 03, 2003, 04:37:59 am »
Yes, the delicate dreamcast controller daughter board uses a  resistor as a fuse. It's a simple fix to replace.
4 screws for the case.
4 screws for the controller board.
1 ribbon cable
1 wire to remove.
Matching the resistor is the trick. I found it hard to find a match for.
saltypenguin
  • Last login:March 07, 2004, 11:30:02 pm
Re:Dreamcast woes
« Reply #6 on: July 03, 2003, 03:10:36 pm »
Are any of your controllers offbrand?  I work at Game Crazy and we've had some problems with this one brand of controller blowing out ports on the Dreamcast.  Of course I can't remember what brand it is, that would be too easy.  ::)  I know it has six buttons on the face instead of the usual four though.
crashdmj
  • Hulk smash!
Re:Dreamcast woes
« Reply #7 on: July 03, 2003, 07:26:07 pm »
Yeah I have an Astropad and a Nyko Dreamaster?? I think the dream one is the one with 6 buttons.
Derek
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Dreamcast woes
« Reply #8 on: July 03, 2003, 07:57:51 pm »
Well one of your joysticks is bad and is causing the problem.  I'd suggest trashing both the Astropad and Nyko pad, and buy real Sega pads (they are what $4.99)?
The problem is one of your pads is grounding out the +5 (I've seen this happen with cheap 3rd party pads used in conjunction with rumble packs).
The fix is as armad stated....its supposed to be a .39 ohm, 1/4 Watt, 10% tolerance pico resistor (but acts as a fuse and simply burns up when the current is to high).  I replaced mine with the smallest real fuse I could find (0.5a I believe) and it works.  Just one note, this will not work for you unless you get rid of your bad controllers.
« Last Edit: July 03, 2003, 08:04:30 pm by Dave_K. »
