Author Topic: future pinball arcade mode help  (Read 10020 times)
reko19
  • Last login:July 16, 2025, 10:06:10 am
« on: April 24, 2009, 11:42:40 am »
their site seem to be down. anybody could help me figure out why I only get a small portion of the table in the bottom corner of the monitor when trying to run it in arcade mode? Thanks.
« Last Edit: April 24, 2009, 11:52:40 am by reko19 »
billpa
  • Last login:October 01, 2017, 11:25:31 pm
Re: future pinball arcade mode help
« Reply #1 on: April 24, 2009, 01:05:10 pm »
You need to resize every table for arcaderender mode. Press the scroll lock key, that will give you options for position, scaling, etc. Page up and Page down keys toggle between the settings. Use the 2,4,8,6 keys to adjust settings. Use the enter key (i think) to move the image center to corner (do this first to get more of the table on the screen). Also, I forget what key it is...but if you hold it down while you adjust, it speeds it up. Much better to move in large increments that way. I will check to see what key that is.
MOST IMPORTANTLY...SAVE THE TABLE in the editor or your changes will not be there when you go back to play.
HTH,
billpa
billpa
« Reply #2 on: April 24, 2009, 01:10:55 pm »
Okay...I found it...hold down Delete key for accelerated movement and hold down Insert key for fine tuning movement. This is in conjunction with the movement keys (2,4,6,8 on the num pad). There is a great help file in the HyperPin forums (it is also included in the HyperPin Install File). You can get just the help file here
http://www.hyperspin-fe.com/forum/showthread.php?t=2464
It lays out what you need to do for Future Pinball as well as Visual Pinball (a bit trickier).
reko19
« Reply #3 on: April 24, 2009, 01:40:01 pm »
got it, thank you for your help
