Author Topic: Just getting started - testing Control Panel layouts  (Read 1778 times)
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
« on: April 23, 2009, 08:03:24 pm »
Started with the cardboard box to get the joystick/button layout.
Then moved to a sheet of MDF to try out different 4 player layouts.
U360s for P1&2. Happ Competition for P3&4.
P3-P1 & P2-P4 sticks are at 45 degree angles and 10" apart for dual 8-way games.
This put P4 closer to the edge than I wanted.
The monitor will be an old 27" TV 1 foot away from the end of the control panel, so I hope it works out with P3&4
severdhed
  • Last login:December 07, 2025, 11:41:29 pm
  • RIP Dinosaur Hippo
Re: Just getting started - testing Control Panel layouts
« Reply #1 on: April 23, 2009, 11:31:37 pm »
dual 8 way games will be tough if the player 3 and 4 sticks are at an angle
mlalena
« Reply #2 on: April 24, 2009, 10:24:44 am »
I've been waiting over 2 months for my Mini-PAC to show up, so I can't even use the panel. I'm just trying to make progress without being able to test.
For the $8 for the cost of the wood, I figured I'd experiment with the layout, play with the router and figure out some of the wiring - I actually have the Mini-PAC harness.
One of my concerns is that my friends take big swings on Golden Tee, so I wanted nothing behind or in front of the track ball in a 90 degree arc. This meant the spinner is next to the track ball and now everything gets wider.
Once I get the Mini-PAC try this out and it doesn't work I will try a smaller angle. I think there is room for the yellow controls, but maybe not for the green controls. I may need to move some other things around.
mayhem
  • Last login:July 11, 2016, 03:37:04 am
  • http://cmaccs.com/
    • C-Macc's
« Reply #3 on: April 24, 2009, 11:28:34 am »
Bring the 1 and 2 player down further and center the track ball more.
This gives more leigh way for you problems.
severdhed
« Reply #4 on: April 24, 2009, 05:28:33 pm »
that's a good idea...the center of my trackball hole, and joystick holes are only 6 inches back from the front edge...this gives you plenty of space to rest your hands, and would open up more area for teh other 2 players.  also would increase the distance between your trackball and your monitor
