Author Topic: I have an idea and curious if i have all the details right  (Read 3121 times)
R0UNDEYEZ
  • Last login:March 16, 2015, 03:39:15 am
« on: April 20, 2009, 03:19:10 am »
Ok currently my arcade controller has a computer in the base of it running mame with mala as a frontend,it has an ipac4 running 4 players with 6 buttons each plus start and coin.for video I run s-video to my television. eventually its going to live in a fullsize cabinet of its own, but space is a big issue at this point and this is something i have room for.I am always thinking of ways to upgrade it in ways that are easy to port over to when its moved to a fullsize cab.I got this idea and I wanted to basicly run it by you guys since i want to make sure i have my facts straight from this research i have been doing.
I would like to be able to use these controllers to also run real games as well, so if i bought one of these: http://www.jammaboards.com/store/images/uploads//JAMMA_Harness_FULL_548x480.JPG
to interface with the board and then get one of these: http://www.jammaboards.com/store/images/uploads/CV-04/RGB_2_Video_Converter_WM_640x427_LR.jpg
so i could output to s-video, and something like this: http://www.wiringproducts.com/contents/media/2109h-outlined.jpg  to piggyback the jamma harness and the wires coming from my ipac into the buttons and joysticks. and get the 5 and 12 volts off the power supply of the pc. that would work right?
anything i'm over looking? for the 5 and 12 volts i need would i be better buying a dedicated power supply?
Level42
Re: I have an idea and curious if i have all the details right
« Reply #1 on: April 20, 2009, 03:12:08 pm »
This should be in the Main section...
R0UNDEYEZ
« Reply #2 on: April 20, 2009, 04:12:09 pm »
I was wondering if I had it in the right spot or not... should I repost it? or will a mod move it?
Level42
« Reply #3 on: April 20, 2009, 04:17:31 pm »
Ask Peale...
SirPeale
  • Green Mountain Man
« Reply #4 on: April 20, 2009, 04:41:26 pm »
It's right.  He's running real stuff too.
R0UNDEYEZ
« Reply #5 on: April 22, 2009, 07:05:47 pm »
no feedback? i can't be the first person to want to do this  :P
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #6 on: April 22, 2009, 09:44:36 pm »
It's pretty much the opposite of the way I would do it, which is wire the cab as standard JAMMA and use an arcade monitor, then interface with the PC using a JPac for players 1/2 and IPac2 for players 3/4. Then I would use a JAMMA switch to flip between the JAMMA board and the PC.
I don't think there are too many Supergun folks here and they would be your best source of info.
Also note that some JAMMA boards require -5V.
Working: Not Enough
Projects: Too Many
Progress: None
R0UNDEYEZ
« Reply #7 on: April 23, 2009, 03:00:25 am »
well, having a real arcade monitor would be pretty nice,but a little harder for me to swing than the option i came up with... not to mention my first main intention was only mame so thats why i'm only just now interested in the jamma thing.I havent come across a jamma switch.. i will have to look for something like that since i was trying to find a way to have it on some sort of switch rather than having to plug and unplug them as i want to use them.
BobA
  • What Me Worry?
« Reply #8 on: April 26, 2009, 11:10:33 pm »
Here is a link for a cheap 6 board jamma extension
eBay Link
