Author Topic: Arcade VGA WG 25" Arc Mon. Resolution and Refresh Rate issue.  (Read 1443 times)
JonProphet
  • Last login:December 03, 2009, 04:35:47 pm
Ok, working on my cabinet as I type. While you guys read this, I'm goin to be wiring up my joy and buttongs to my iPac 2.
Here is my problem. Hardware is a P4 3.2 Ghz 1 GB ram. I have the PCIe 2 version and the driver installed fine for the card. I'm not using the JPAC but the adapter to boost the 5v signal to the RGB sync.. etc. I do have picture, but I'm at 640x480 resolution in Windows and I can't change my refresh rate any lower than 59Khz.
I also have an unknown item in my system. Not sure what it is. It could be my on-board video. I didn't think of that. I did install the drivers but the ATI panel isn't showing either.
Am I doing something wrong?
Thanks,
-JD-
Ummon
  • Trade Count: (+13)
Re: Arcade VGA WG 25" Arc Mon. Resolution and Refresh Rate issue.
« Reply #1 on: April 20, 2009, 04:38:01 pm »
<in a bold, 50s style> MO-NI-TOR WI-KIIII. Why? What is refresh? More importantly, what is scan rate? Then come back if you still have issues.
Yo. Chocolate.
Stephen Hawking
JonProphet
« Reply #2 on: April 20, 2009, 11:16:12 pm »
Ummon, thanks for atleast responding to my post even though it wasn't helpful.  ::) :'(
I've read the monitor Wiki. I have a feeling that everything is working as it should. I found that you can drop the resolution to 640x288 and the refresh rate is better with no flicker but Windows is next to useless.
-JD-
