Poll
Which aspect ratios do you use when playing MaLa?
1.25 (5:4)
1 (6.7%)
1.25 (4:5) Vertical
0 (0%)
1.33 (4:3)
8 (53.3%)
1.33 (3:4) Vertical
4 (26.7%)
1.6 (16:10)
2 (13.3%)
1.6 (10:16) Vertical
0 (0%)
1.78 (16:9)
0 (0%)
1.78 (9:16) Vertical
0 (0%)
Something bizarre (not listed)
0 (0%)
Total Members Voted: 13
Author Topic: Aspect Ratios - What size do you use with MALA?  (Read 4529 times)
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
« on: April 04, 2009, 02:58:19 pm »
When making layouts for the masses, this question always crosses my mind.  I'd like to know what you guys use.
* You have up to 3 votes if you have multiple machines.  Please don't vote more than necessary.
* I'm not concerned about a system you test with.  MaLa on a cab, vote it.  MaLa frequently played on a PC, vote it.  I want to know what size you actually enjoy MaLa on.
This will help me, and hopefully others, make more layouts that more of you can use.
Thx,
system
« Last Edit: April 17, 2009, 07:19:56 pm by loadman »
system01
Re: Aspect Ratios
« Reply #1 on: April 09, 2009, 02:59:57 pm »
60 views and 4 votes ???  C'mon guys!
BUMP!
loadman
  • Moderator
    • MaLa
Re: Aspect Ratios - What size do you use?
« Reply #2 on: April 09, 2009, 09:45:01 pm »
opps
3:4 Vertical
Neverending Project
    • Arcade Fixer
« Reply #3 on: April 10, 2009, 01:31:25 pm »
800x600 FTW!
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #4 on: April 10, 2009, 05:51:47 pm »
This pool could been defensively been posted under softwareforum  for any frontend users (Which aspect ratios do you use when using your frontend?), since this is a very good general question....
My work machine use 16:9 and my arcade machine have a 5:4 LCD monitor, so.....
Just a idea, should this post moved to software forum?
« Last Edit: April 10, 2009, 05:55:33 pm by Space Fractal »
system01
« Reply #5 on: April 11, 2009, 11:59:03 am »
I'm fine with that.  There would be a much better census with that big of crowd, too.
Can loadman move these up?  Should I ask a mod from Software?  I could just start a whole new poll and point this one to there.
loadman
  • Moderator
    • MaLa
« Reply #6 on: April 11, 2009, 06:00:36 pm »
I could move it but I think it would be good to have a seperate MaLa one too  ;)
system01
« Reply #7 on: April 12, 2009, 12:53:42 am »
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #8 on: April 12, 2009, 10:19:20 am »
I think pool about this one should been closed, since it never good to have two post about the same question. Since I doesn't use MALA (due I of course use my own MultiFE), I have vote in the software forum instead, but I like this question.
Howover the original post could do for othe FE and point to this one for users for MALA.
« Last Edit: April 12, 2009, 10:21:54 am by Space Fractal »
system01
« Reply #9 on: April 12, 2009, 12:24:39 pm »
Now that I have both polls side-by-side, this one does seem rather redundant.  I am locking the voting on this one.  I'll leave it up to loadman if he wants to remove it.  A MaLa poll should show a similar result to an "all FEs" poll anyway.  MaLa - or any other FE - does nothing special in the screen-size department.
Again, vote in the software forum:
http://forum.arcadecontrols.com/index.php?topic=91428.0
