Author Topic: Bug? : first time run  (Read 2039 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
« on: April 04, 2009, 09:09:25 am »
I've noticed something that could be a bug. When you load MaLa, the first time you run a game, you see the loading screen, and then, just before the game is displayed, you see the gamelist for a second. It's like a blink. This doesn't happen anymore when you load games later: you see the loading screen and then the game, as expected. Does this happen to you? I have not tried in high res. I'm using a 320x240 layout and my games are loading in native low res.
« Last Edit: April 04, 2009, 09:27:35 am by loadman »
loadman
  • Moderator
    • MaLa
Re: Bug? : first time run
« Reply #1 on: April 05, 2009, 02:18:33 am »
I tried it on the latest beta and could not get it to do this.
Note: this sounds like it is more of a windows type issue as the mala game list is always there underneath, the game window is loaded over the top of it.
