Author Topic: Gottlieb ball kicker part number needed.  (Read 2354 times)
Cyberflexx
  • Last login:October 12, 2012, 03:40:10 pm
« on: March 26, 2009, 10:43:50 am »
I dont have a parts manual for the machine but maybe someone here may have an idea of the part name or number that I need.  I will also need to find a place to buy them online other than pbresource since you cant order online like every other store on the net.
I need the plastic insert that is in a Gottlieb ball kicker.  These are sometimes Red or white plastic and they sit in the bottom of the kicker hole on the playfield.  I was doing my playfield swap and when I took the kicker off, the plastic peice just broke into a few peices.
I will need two of these one red, one white or 2 reds...
« Last Edit: March 26, 2009, 10:45:42 am by Cyberflexx »
shardian
Re: Gottlieb ball kicker part number needed.
« Reply #1 on: March 26, 2009, 11:49:52 am »
pbresource is different to order from, but not all that bad really. I wish I knew you needed these a few days ago, because I just put in an order with them Monday.
If you call them and tell them what you need, they'll send it to you quickly, along with an invoice. I even got a nice woman this time on the phone instead of Steve.
Cyberflexx
« Reply #2 on: March 26, 2009, 01:08:37 pm »
I found the parts, they are 2 seperate part numbers.  Marco had them, but only in an amber.  This will work until I can get a red to replace it..
