Author Topic: K4600 Issues  (Read 2256 times)
SirPeale
  • Green Mountain Man
K4600 Issues
« on: March 24, 2009, 08:00:00 pm »
Have a K4600 that WAS working perfectly.  Right until somehow, someway, the neckboard got split in two.   :censored:  INSIDE a damn cab.
Tube is okay, so I attempted to put it back together.  Everything /looks/ okay, I have continuity on all traces.
I've got high voltage, at least I'm pretty sure I do because the screen gets charged with static.  No neck glow.  I've checked and double checked the connections on the neckboard, all appear to be sound.   R422 reads @ 1 Ohm.
I'd read the heater voltage except I've read that you need a true RMS meter to get an accurate reading, and of course I don't have one.
Any ideas?  I'm clueless here.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: K4600 Issues
« Reply #1 on: March 24, 2009, 10:21:32 pm »
depending on the crt size/type , filament pins are 4,5 or 9,10
with "neck board" diconnected , u should read a low res across these pins on the crt .
with same condition above , u should also read a low res across the same pins on the skt.
if not , there is a break in the fil winding.   note : usually one side of the winding is ground
qrz
Kevin Mullins
    • Me on Myspace
Re: K4600 Issues
« Reply #2 on: March 25, 2009, 01:09:29 pm »
It ain't missing the ground somewhere is it ?
(on the neckboard itself)
qrz
Re: K4600 Issues
« Reply #3 on: March 25, 2009, 03:29:47 pm »
usually , there is a single ground pin on the fly.
several windings are then referenced to that pin.
removing the socket breaks the loop . so, u should read low res from either fil pin to gnd  ....
qrz
SirPeale
Re: K4600 Issues
« Reply #4 on: March 26, 2009, 09:45:43 am »
QRZ: define "res".
qrz
Re: K4600 Issues
« Reply #5 on: March 26, 2009, 07:11:46 pm »
sorry, been at this so long i tend to forget others are not so familiar with the technobabble.  :-[
just another hazzard of being an " old fart "
low resistance.   in this instance < 1 ohm
qrz
SirPeale
Re: K4600 Issues
« Reply #6 on: March 27, 2009, 12:17:31 am »
I get the technobabble, but sometimes I have trouble with your abbreviations.
I'll check it out.
SirPeale
Re: K4600 Issues
« Reply #7 on: April 14, 2009, 11:27:37 am »
Finally got around to figuring this out today.
When I said I had continuity on all traces, what I meant was all traces that were torn in two by the neckboard cracking.
There was one that I missed.  You guessed it - one of the heater traces.  I thought it looked iffy before, so I checked it and sure enough...zero ohms.
Hit it with a soldering iron, and it was sliding all around.  Just a solder pad not attached to the trace!  Hit it with my fibreglass pencil to bare copper and now it's working fine.  Needs recapping, but working again.
SirPeale
Re: K4600 Issues
« Reply #8 on: April 15, 2009, 06:52:56 pm »
One recapping later and it's awesome.  Didn't have all the caps to replace, but I got 95% with what I had on hand.  Has improved things 100%.  Amazing picture, considering the sheer amount of Pac-Man and Shinobi burn.  The tube is brown from it, yet gives a great picture.
