Author Topic: can someone point me in the right direction?  (Read 839 times)
onlyasaint
  • Last login:June 01, 2009, 04:54:23 pm
« on: March 23, 2009, 10:32:17 am »
I recently bought a built jamma arcade cabinet from someone. It came with TMNT. I figured out how to switch out the boards however i have two questions:
1. I bought x-men and i have no clue how to wire an additional button for the arcade?
2. How can i make a board that is four players, compatible with a two player arcade to choose whoever i want (i.e. TMNT or Sunset Riders)?
onlyasaint
Re: can someone point me in the right direction?
« Reply #1 on: March 23, 2009, 01:55:06 pm »
ok found my answer for the EPROM question 2....however i need help with the wiring of a third button for the arcade...any help please!
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #2 on: March 23, 2009, 02:39:19 pm »
1. Third button -- check the wiring harness, starting at the edge connector (where the board plugs in) and see if there are wires coming from pin 24 (Parts Side) and pin b (Solder Side) -- these pins are 5 in from the end of the connector (see below). They may or may not be labeled on the connector, but they will be on the far end from the black, red, orange and yellow wires at pins 1-6. Pin 7 is a "key", which is hopefully indicated by a white piece of plastic inside the connector itself.
If there are wires there, then trace them as they likely aren't connected to anything. Connect those wires to the "NO" connector on the button switch (24 is for Player 1; b is for Player 2) and connect the "COM" connectors to the ground (pins 27,28,e,f ... or the "COM" connector on an adjacent button).
2. Not always possible, but where it is ... HobbyROMS -- Steph is the man!
Working: Not Enough
Projects: Too Many
Progress: None
onlyasaint
« Reply #3 on: March 23, 2009, 04:35:35 pm »
thank you that was extremely helpful i have to check that out. quick question if I add the third button will it affect any two button game i also have?
CheffoJeffo
« Reply #4 on: March 23, 2009, 04:45:55 pm »
Nope.
EDIT: Oh yeah ... WELCOME!
Working: Not Enough
Projects: Too Many
Progress: None
