Author Topic: Mounting an I-pac  (Read 3407 times)
Chris falco
Mounting an I-pac
« on: March 03, 2002, 02:28:51 am »
I just build my control panel, and I was going to mount the I-pac to the underside so the wiring dosent have to hang down and is close to the board, the problem is the holes in the I-pac's corner are so small I cannot get any machine screws through it!
My control panel is 1/4inch hardboard so I cannot nail too far into it or it'll stick out,
any ideas?
thanks
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
Re: Mounting an I-pac
« Reply #1 on: March 03, 2002, 04:11:36 am »
If you have access to nylon standoffs that are used to mount motherboards in older P1 style pc's these will snap right into those holes. Then you can epoxy the other end of the standoff to your C-panel. This should hold the I-PAC above the surface of the wood and provide some air flow around the PCB.
                           good luck
                           Slug54
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« Reply #2 on: March 03, 2002, 05:45:17 am »
I had the same problem I took drill bits without the drill and worked them through the hole till it was a little bigger. It worked and it's now mounted.
ArcadEd
« Reply #3 on: March 03, 2002, 09:09:05 pm »
I just used #6 or #4 wood screws with nylon spacers.  One in each corner.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #4 on: March 04, 2002, 02:17:28 am »
Some hot glue and the nylon spacers work just fine too if you can't find the right size screws around the house and don't want to go to the store again.
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: March 04, 2002, 03:38:01 am »
If you were trying to use machine screws, Radio Shack should have some 4-40 screws that should work, otherwise, any of the options above or double-sided foam tape like they use to hang mirrors is another option.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #6 on: March 04, 2002, 12:26:59 pm »
I just mounted mine using 3/4 inch #4 screws and aluminum spacers that I got at Ace Hardware.  #6 screws are just a bit too large.
American Laser Games Wrapper
O2em Rom Utility
